Justin101
Hi All. big hello to all here.. what a great forum.
I have a simple question.
I have an area of wall that requires Thistle bonding coat to be applied up to a thickness of around 22 mm. I am aware that the maximum thickness of said bonding coat is 11mm. Is it possible to slowly build up by bonding coat in layers... i.e one coat of 11mm, scratch it... and then apply a second coat of 11mm which would bring me to my 22mm. If this is possible then what would you reccomend the drytime between coats (room is well aired and around 16 - 20 degrees C).
The wall will then be covered in Thistle multifinish and then Tiled using tiles that are less than 20kg per metre square.
The background is aircrete blocks that have had PVA applied (to the manufacturers recomendations), the aircrete blocks are now showing little to no sign of absorbtion.
many thanks
Justin.
many thanks
Justin.
