Rigsby
TPF Special Forces
I am consider getting a set up for spraying buckets coats through my Ritmo. A question about what you do with the material that will be left in the pipe when you have finished.
I have worked out that there will be 7.5 litres of material in a 15m pipe. That is half a tub!
So when I have finished the spraying can I put the Ritmo in reverse to pump the material out of the pipe back into the hopper then pump it out of the hopper into a bucket from the R&S?
