Vimark base coats, OCR
Bauwer
Fiber reinforced Vimark OCR base coats.
What base coat to use, at which substrate type, how much is it costs?
Fibre reinforced breathable Rasolite is going over old painted solid render externally or as a renovation plaster internally.
https://www.vimark.co.uk/products/rasolite-fibre-reinforced-base-coat/
Fiber reinforced Monochrome grey is applied over non-homogeneous substrates with block work, brick work or stone work.
Link Removed
P16 OCR is basic breathable base coat to go over brick or block work.
https://www.vimark.co.uk/products/basecoat-render-beton-p16/
Polyfix is an adhesive and base coat for the external insulation system and cement render carrier boards.
https://www.vimark.co.uk/products/adhesive-base-coat-for-external-insulation-system-polyfix/
Contact us for specification and price competitive quote at info@vimark.co.uk
More information at vimark.co.uk
With the ocr p16 how many m2 does a bag do at 15mm ?
Used a couple of pallets last year and love the material but can’t for life of me remember m2
One bag of P16 covers 1.19 m2 at 15mm thickness. P16 could be sprayed or manually applied, it contains hydraulic and air-cured special binders, selected calcareous aggregates and specific additives that improve its workability, breathability and bonding strength. P16 could be finished with thin coat COLOR.VK in three grain sizes and wide selection of colours or mineral finish Arenino VK2:
Fiber reinforced silicone thin coat COLOR.VK
https://www.vimark.co.uk/products/silicone-render-color-vk/
https://www.vimark.co.uk/wp-content/uploads/2016/01/COLOR_VK_0217_ENG.UK_.pdf
Mineral finish Arenino VK2
https://www.vimark.co.uk/products/mineral-topcoat-coloured-render-arenino-vk2/
HYDROSEAL is waterproofing mortar for retaining walls, masonry, concrete and prestressed concrete. It is used for repairing masonry and underground substrates subject to water ingress and counterthrust (negative pressure). The product is suitable for waterproofing tanks, reservoirs, concrete pipes, wet rooms, elevator shafts, foundations, irrigation canals, underground walls and is suitable both internal and external use:
https://www.vimark.co.uk/products/osmotic-cementitious-mortar-hydroseal/
