Told them I can't be arsed with getting the machine out for 40m2 and definitely can't be arsed to do it by hand.Price the customer on both and let them pick.
We offer two options going over tired painted solid render. First one fibre reinforced Rasolite as a base coat with thin-coat finish. The second option is also robust but considerably cheaper alternative and easier to apply - Arenino mineral thin coat with addition of 1 liter of Vimarlatex 663 per bag. The second option is generally preferred for more flat substrates and possibly could be sealed with Vimasil Aqua siloxane sealer as an option.
Hi Rigsby, I'm still debating using rasolite. You mention it is waterproof, I wasn't aware of this I thought it was only lime based. Must be the additives in the mix.Used the Rasolite. Good gear. Get if flat and key well, totally waterproof.
@Bauwer , do you have any off white colours in arenino ? Cheers
There are 24 colors of Arenino, including off white, also we stock just white in the UK as it is the most popular option. We could deliver other 23 colors within one to two weeks. Also could you tell me more about your project?
Its a renovation project with different backgrounds of painted render , new unpainted render and old blocks.
Im looking to use rasolite as a base on the painted and blocks and finish with arenino . The client wants an 'antique white' or off white finish.
Cheers
Anyone got any pictures of jobs finished in rasolite?
Hi, Did your client pick Arenino finish? I was looking for an antique white also. Sample of ivory looks a bit of a cream colour. Don't know whether it's worth getting a bag to see the colour on a larger area.Its a renovation project with different backgrounds of painted render , new unpainted render and old blocks.
Cheers
Really, I've found out since I posted that that it's not a finish but if you have pictures let see um then mateYep.
Internally such as what Alex ? For dubbing areas out etc ?Fiber reinforced Rasolite is a base coat and not weather proof, so need to be finished with a thin coat. Also Rasolite used internally as well for repairs and maintenance. Rasolite base coat over tired painted render:
Current project using Virmark. Patching and floating over old brick in Mono.chrome grey. over solid painted render with rasolite.
Going to spray vk 1.2 silicone topcoat over all 12 houses next week.
Both rasolite and monochrome are excellent. spray lovely and can be built out really thick without slumping. must be the fiber!
@Bauwer r can I use rasolite internal for patching then skim next day ?
NEW VIMARK RENDER STOCKIST! Vimark Render is pleased to announce that FS Trade are now stocking wide range of Vimark renders, including full scratch render system Monochrome in five popular colours. Other material in stock includes fibre reinforced base coats Rasolite which can be used directly on old tired renders and painted surfaces, fibre reinforced Monochrome grey, over brick and block work base coat as well as high adhesion primer Monogrip, siloxane sealer Vimasil Aqua, insulation adhesive and base coat Polyfix, fibre reinforced silane-acrylic thin coat Color.VK and cost efficient thin coat Arenino VK2 and many many more are available on order.
Please contact FS Trade at 0151 363 1677 or visit at 5 Wilson Rd, Liverpool L36 6FH
What is best point of contact for The South West, I'm only just catching up on this system
