Vincey saves the day
Glad you got it done and out of the way. Sorry I couldn’t have mucked in.
What was the Ritmo problem?
It blocked when he dropped the water to stiffen it up a bit.
Bit of head scratching, stripped it down and washed it out. Jobs a good un
Easily done if the tap gets turned too fast and too far. Causes a jolt in the mixing zone. Was it a jammed r&s or blocked pipe?
Mixing chamber was clogged upto the top , hose was ok
Think L1 is under current? Motor stops but water carries on or vice versa. Had a lot of L1’s last year. Caused lots of trips.
It was both my flexs that had seen better days. Got 4mm cable for the Ritmo and 2.5mm for the water pump. End of lots of electrical problems.
Flexs have a short life. Usual the breaks are within 300mm of the ends. The strands break down over time.
