The top coat could blow if theres a big f*ck of crack in it and lots of water gets in and freezes...although its more likely the whole lot will come away from the wall.
Spunky I've just noticed that your almost at 10000 useless posts. lol Don't think I've ever read one of your posts which has not just been a one liner of inane bullsh*t! More smilies pls.
Hes not got a scooby doo, reminds me so much of OasisYou don't know what the **** you're doing do you lol
Flynny why don't you phone up the guys who make these products and ask them these questions. As a moderator you should be giving the correct advice.
Ok and the frost won't cause a crack on a render without waterproofer in the top coat? and the problem won't get worse?
Depending on the type of construction waterproofer maybe used in the mortar.
What type of construction is that? im always willing to learn.
Do you know him? I dont but i think he is an arsehole.Oasis is a good lad, i've got respect for him. He will no doubt do well for himself, hes got the right mindset.
Everything we discussed above Flynny pls note improved frost resistance...and supplements/replaces lime.
xxx
Your the one that hasn't got a clue or is stuck in the 60s xxx
Good judge of CharacterSays alot about you then doesn't it
Well they wouldn't say put it in the top coat because that really depends on what rendering is being undertaken and what time of year. But if you think about it where does a frost occur?
Problem is Flynny you think you know it all.
How does a retarder protect against freezing conditions
Do you think waterproofer protects you from frost?What would be the point of having protection against frost if you didn't put waterproofer in the top coat?
Retarding is a process.
