What is this? Looks like skim over ply/mdf
cornsack
Working at a customers house this morning with paper lined ceiling. Was thinking i'd probably overboard rather than strip anyway but can someone tell me what this is?!
Just started checking whether it was lathes or plasterboard and it's neither. Have never come across this before, looks like mdf or ply but has a layer of pink plaster on it before the paper. It is well bonded but I'm confused, never seen this before.
  • What is this? Looks like skim over ply/mdf
Yeah it's 1930s house. Some of the walls have it, other parts it's solid plaster. Guess it's alright to skim over on the walls as it does have a layer of pink plaster over it.
Was just interested as never come across this before. Didn't think you could plaster over a background like that either
Have you come across any of the joints in the old board?
If it's the board I'm thinking of they had a paper faced, sticky backed scrim that would be put over the joints and then the whole surface would be painted. No plastering originally.
It's just the ceiling and the lintel above the windows/door that have this stuff actually but it's all covered in a coat of pink plaster. Found some of the old thick stringy scrim but no paper backed scrim.
I guess this stuff wasn't used for a long period then.
Seen this before in old council houses but can't remember the name but as far as I can recall is a messy s**t to take down, breaks up and as dusty as bejasus.
Tintest board, also known as Essex board. it was manufactured at Airscrew Weyroc at Marks Tey, Essex. it goes out of shape as there is no strength to the board. it could be skimmed the first coat would pull in quickly 2nd coat ok.
Well I was quite close with the name @malc
Fountain of knowledge
