where to buy k rend
can you use joint beads in k rend to section it off? or does it need to be in one hit? and should i sbr the block work?
Its 15mm thick render spec for all monocouche. How u get that is up to u.
I use 15mm bead, others use 10mm bead and mess about wasting time dabbing 5mm of adhesive and bedding them up and plumbing
Whatever suits you personally
you can mix on the scaffolding but you need water on every lift or hose pipe next to you you must keep the line wet ,then you dont have to go 20x faster, one mixing one laying on , dont try it alone.:RpS_wub:
2 big tubs so while you are using one the lab is mixing the other.
As for setting? Summer same day scrapes has gone. But a bit early for overnight too.
yes i think he does , scrape, from 4 hours to 16 hours, but u have to judge things,its down to experience:RpS_biggrin:
