Cheers, is there a difference with speedskim and ox speedskim, or have they been bought out?If you only get the one then 100% id go for the blue plastic (ST blade) it's the dogs bollox in most scenarios.
And light years ahead of that original grey blade.
for Flattening and the first couple of passes it's mint
While it is possible to finish with it to a good standard it can be a bit hit and miss if timings are not bang on, so for the final pass i give it the last flick with a medi-flex.
The blue blade speedy also closes hardwall and ocr up a treat.
Personally I think the blue blade speedskim is the best thing Ive bought in the last 20 years.
Do you use your medi for anything else, like 2nd coating? If not why not?If you only get the one then 100% id go for the blue plastic (ST blade) it's the dogs bollox in most scenarios.
I've not tried it for owt else yet, but I'm finding my medi is tearing on last pass, maybe timings or not enough water?
It's 3 mth & used quite a bit but reverted bck to mt a lotHow old is the medi? Have you used it much? These flexi trowels and the speedskim SF do tear a bit when new so you have to hold them flatter to stop it..... That will bringg a new set of problems so personally I rubbed mine of a lovely new screed to take the edge off.... now it's worn in and i love it when I use it.
Would you advise wet & dry or a wet stone, don't get near any screeding
Is it just the final pass for you or have you tried laying on with it?
Looking to buy a Speedskim 600 been using the Ezz spatt for yrs and want to see what the Speedskim is likeHi mate, no difference at all - we are still in the process of changing some listing descriptions to show the new OX branding, but anything you do purchase has now been changed to OX Speedskim.
The products and blades are exactly the same profile and haven't changed - the only changes are slightly different blue and changes to stickers.
All made under the same roof and made in the UK![]()
you have replied to a two year old post.Looking to buy a Speedskim 600 been using the Ezz spatt for yrs and want to see what the Speedskim is like
Would you recommend the plastic blade or stainless steel
Tks
He might of been off sick! Or in a coma for 2 years and just switched his phone bk on!you have replied to a two year old post.
So What ! The lads keen, cut him a bit of slack ! Ya pair of knobs .you have replied to a two year old post.
I would'tn bother mate, better of with spats, I like the Nela's personally. Refiina's are ok too , Welcome and good luck .hi, I'm looking at getting a speedskim, I have used one before (the original with plastic edge) but looked online and there are speedskim and ox speedskim, with a blue finishing edge or a small edge, any advice?
CheersNaelkas
Stick with the spat , ss . Imo. I like the nela'. The 450 speed with stainless has good reviews though, handy for top landings ( all around the doors )Looking to buy a Speedskim 600 been using the Ezz spatt for yrs and want to see what the Speedskim is like
Tks
Tried both, have s skim 600 and both blades, depends on the job, prefer the steel though.Looking to buy a Speedskim 600 been using the Ezz spatt for yrs and want to see what the Speedskim is like
Tks
Knackered if you want to use it on a ceiling from a pole thoughI’ve been buying the speed skim blades for awhile and using h section and window casket to make our own speed skims cos they are all overpriced. I’ve just done some for a lad on site View attachment 39783
Yeh course but a bit messing round thoughHi I’m new to the group and always jumped on forum to be nosy lol I’ve invested in ox speedskim plastic blade 900 just wondering if I bought a replacement steel blade 900 would it fit into the plastic blade if removed thanks
I use the speedskim to flatten 1st and 2nd coat, lay on with mt and trowel up using ox ultra flex.It's 3 mth & used quite a bit but reverted bck to mt a lot
