who makes the best trowel/s these days
After I put on with and laid in second coat with mt if on boards will do all my flattening and final trowel with blue plastic..as long as corners are bent back you will be fine.. around sockets or light cables use mt to quickly tidy round them but will get to final finish with blue blade
Ive been thinking of rounding the corners on mine cos it does leave lines, have you just bent yours slightly?
I would be really interested to see finishing with speedskim....like someone else said would have thought it had to much flex....i seen finishing with eze spat but that seems a bit stiffer.
I have not tried to finish with the speedskim, I only got the grey one which served me well getting it nice and flat, I only bought a little blue blade one a few weeks ago. If it gets it nice and flat then need a tickle with a trowel that makes me happy enuf
Seeing as tho I made this thread to find a new trowel I decided to order a refina plastercraft with a cork handle
I did once when working with a mate.we both decided you don't need one as the walls are flat enough anyway
Fair enough if you've tried it and didn't like it. I'd say the main benefit for me was not just getting walls and ceilings flat but you get them under control much quick with a lot less effort
There's always room for improvement no matter how good u are why ldnt ldnt ldntulike ldntulike make it easier especially as ur getting on a bit:club:
If that's what you think fair enough.I don't think you do.We will have to agree to disagree
I don't understand what the speed skim is all about.i bought one and thought it was s**t
How much do the speed skim weigh ? I've got a .EZE Spat 600mm and a 1 meter I was wondering what's the weight difference?
@theplasterman....so are you doing s set on a ceiling the whole way through the troweling stage with a blue blade???
I have a grey blade but only use for a quick flatten straight after putting on then just trowel ad normal!
Wow...that sounds great have you done a few like that or just that perfect plasterboard room you creamed the other day!
On boards I do it just keep trowel clean not to much pressure at the end .. Overskimming old s**t jobs 1st 2rd try for final if it needs it pull nela or Mt out..if I can get a video up in next few weeks I will if that helps...but think u should just try it u know what u doing
Speedskim does get it flatter at a much earlier stage, that much can't be argued.
Not using them or a spat of some sort on ceilings is just plain crazy.
And I only started with them 6months ago.
