will it do it ?
yes, carry out a pump test first on the rot/stat and use your pressure guage plus make sure you have someone on the machine who knows what he is doing. Get your material through the pipe before you take it up the scaffold
rich, we pumped ecorend up 4 scaffold lifts with 20m hose on in single phase by mistake the other day and worked for a while so would have thought she can handle it no probs in 3 phase.
Ive sprayed 40m from machine 3 storeys high with an s44 no bother like blones said run your material through at ground level first
I can always remember years ago on the old firm i worked for they had a utiform and it woulnt push the gear up that far .... mind you they were proper wan.kers.
Thanks grand .... t.wat
he's a welsh man with a big nose and a little willy. ;D ;D, merry the lamb face book page that he had a small willy.
yes it will rich.
