Jgreenplastering
Further to the other post about tape what protection do you lot use for the Windows?
We've always used window protector rolls but I see a lot of people with plastic sheeting they cut and tape?
Is this easier/cheaper/better?
With white upvc you don't need to be so precise but with say anthracite or dark wooden window, do you guys tape them
Right up and then cut back carefully once set to remove the tape without leaving some along the render line or do you stick it on precise and scrape back to you so you have a clean line?
