When you apply backing coats (bonding/hardwall) or sand and cement as been right handed, what way do all of you work? As skimming is left to right, I was taught floating should be right to left? Was on a job at the weekend with a plasterer and he was floating left to right then skimmed it left to right? A couple of weeks ago I was bonding an uneven wall out and I started from the right and worked my way over. I then skimmed it left to right. Even that job the plasterer asked me why I was floating right to left. He said he only floats left to right the same as skimming. Even the plasterer I was with at the weekend said the same? I have always been taught floating right to left..because when you put your first band of bonding on the far right, the next band of bonding gets applied to the left of it, the heel of the trowel passes over your previous band! It makes sense...
