Plaster has a chemical set so max you get is 45mins and if there is suction then it is less...
An experienced plasterer can get over anything A newby will struggle with plasterboard...
I mean I can only speak from experience but I find plaster is still playable for much longer than 45 minutes
Once I have put the second coat on I keep a bit spare to fill in any scratches or dents and find it is still easy to plaster in for much longer than 45 minutes. It's sort soft wet hard rather than dry hard.
I think the instructions on the Thistle bags say a job should take about 100 minutes
