Ok then can you answer me a few questions please:
(these are all things that you've said on here)
1) You said your 26, but then somewhere else you said you left school 12 years ago? :RpS_unsure:
2) You said you've been plastering for:
•Just under a year
•2 years
•A few years
•5 years
So which one is it? :RpS_unsure:
A quote from yourself - "I may be new to the forum, but I'm not a newbie as far as plastering is concerned." :rolleyes)
3) You said before your recent Transit connect that you had a bigger Transit "FOR QUITE A WHILE" ?
4) You said your boss is always happy with your work,
Even though you mention that you work for yourself? :huh:
5) How many jobs have you really done?
As you have only mentioned working on your own house, your grans house & your neighbours house ?
This to me sounds like someone who is just starting out, plus the problems your having with mixing & getting multi on the wall!
So come on Marshy the truth? :RpS_thumbup:
That is all for now![]()
when you say slightly sloppy you mean stiffish?
so its not piss wet and its not stiff im not being funny marshall but you should have a bucket -1 bag on in around 15-20 mins mate which off your setting times 45 mins should give you 30 mins to mess with it if need be, i put one bag on then knock a fresh one up use three parts of that then turn around and lay it down all within an hr the rests just troweling up so it works out to a 2hr-ish set depending on temperatures and other factors ,its either your not using the gear fast enough or tartin around with it to much you not have a spot and stand?
I can get a bag on in 20 minutes without too many problems, but the plaster was setting in the bucket before it even got near the wall.
even though I do have a stand, I am on the look out for a new board after a labourer threw mine in a skip.
Marshall just go & buy some multi or board finish from somewhere else & try that.
Where did you get the gear from?
maybe he should try unifinish..................:RpS_thumbup:
You're not adding rapid set cement to your plaster by any chance are you? Just wondering??
Stone cold busted.....................:RpS_laugh:
so if your buckets are clean drill is clean water is clean and you can get it on in time how the feck is there any left in the bucket!! seriously use a spot and stand it will give you a bit more time not loads but a bit more if its sealed proper so it doesnt suck the moisture out of stuff also you been checking the dates on the stuff you been using?i had a customer that had a bag of carlite bonding out of his garage and was adamant i use it to save him buying one it was 3mnths out of date so i explained what would happen to him if i used it wouldnt have any of it so i made the twot stand there and watch me knock it up needless to say he had a new ceiling rose within 5mins so if the stuffs out of date theres your problem other than that dirty tools or not being used fast enough mate
weve had rakes and rakes of multi over the last couple of weeks and its all been spot on, we go out of a bucket as were usually in and out of different rooms and not had one problem so if the multis fine and working out of a bucket is fine the the problem must be with the person on the end of the trowel
There must be some problem with it, otherwise this thread, WTF is going on with multi finish wouldn't have been started.
so I'm not the only one who is having problems, but I am the only one being slagged off.
You're not being slagged off there mate. Just a bit of banter that to be fair isn't completely unjust. Incidentally i was wondering if you'd like to buy a set of left-handed screwdrivers???
Your not the only one, i had a bag start setting really quick, but i knew what to do. Work faster. I found that if you knocked it up in the tall white hard plastic buckets, it sets quicker in the bucket ( but its on the wall before this happens ) If you want a spot board, go and buy one? or find a skip and find an off cut. 45 minutes setting time? I wouldn't stick to that. OR mix it in a big rubber bucket, it don't set as quick in one of them, i've found anyway.
this thread was started 10 months ago
was it ?feck me thats why then hes using the same stuff from that date:RpS_laugh:
well marshall i cannot help you anymore mate if i was you i would knock some up wait for it to go off then take it from where you bought it from and nail it to the sausage jockeys foot behind the counter to cause him as much pain as he has caused you if it goes off that quick you can knock it up in the feckin shop save your fuel
Are there some subliminal messages hidden in your posts? your not the knauf rep in disguise are you.
