You work it out !!!
3 bed semi midlands . Supply & fix 115 8x4 12.5 mm
75 to walls all adhesive to walls 40 overboard to ceilings
Pva to walls prior to install
22 thin coat beads 2.4
Plaster skim finish
£3,250
Discuss :)
:coffee:
Thought pva was a
No no when dotting
I.ve used pva(watered right down)but read on here it's bad practice.
Don’t believe the shite that the dab sticks to pva n not wall. Pva will re emulsify when dab hits it. It’s just a waste of time and pva. As @zombie says blast with water if needed n also gives the wall a drink so dab doesn’t dry too quick n give a weak bond
Plaster skim finish
£3,250
Discuss :)
:coffee:
Materials alone is well over a grand, probably £1200. If any mugs doing all that for 2k labour then they aren't running a business they're running a charity. Be lucky to get £100 a day out of it
Bad practice is sticking boards straight on to a pourous and dusty background. It doesn’t allow the adhesive to set at a normal rate hence breaking the bond!
