I joined the one coat crew today. Done as you are saying aswell. Mixed slightly stiffer and coated slightly heavier. Would say its kinda dodgy on re skims as auctions not all the same but on board work it come out just as nice as 2coat work. 2 sets shaves 2/3 hours off my timeLol I'm in the 1 coat crew now dont know what it will be like going back to 2 coating seems like double the work, but one thing we are doing different is mixing slightly stiffer on the one coat.
to all TRAINED spreads,don,t reply to anybody who thinks they should skim in 1 coat, probably brickies
Yawn
Are you yawning so you can accept a large c0ck in your mouth?
:RpS_biggrin:Pair of wankers :RpS_thumbsup:
Rubbish 90 percent of the time it's the bloke putting it on the wall who makes a difference
Lol I just remembered I have seen you're work and it was s**t you tosser :RpS_lol:
When using BG finish, The first coat is to find any imperfections preventing the perfect finish and the second coat is to produce the perfect finish... NO truley professional plasterer would use any other method, you CAN tell the difference !
got the right name.comes from a loadda ol bollecks!!Shut up you prick boards cock on 99 percent of the time, argue the toss about flattening the first coat then another coat or putting a coat on then l laying a tight second coat straight over the first or one thick coat blah blah ......you're just another bloke who knows fook all ......If every plasterer 2 coats work would be better let's ad this as a sticky because 2 coat is better than 1 obviously thats why when we turn up on a building site 2 coat work is perfect no snagging etc it's just the lads that 1 coat lol
Well he hasnt said 'yes' so until then ..........I would say yes![]()
