essexplasterer
Met a plasterer that only ever throws both coats on at the same time like out of the same mix anyone else seen this?
Used same mix plenty when is small area or just need get away quicker even if I've had to piss it down a bit. Sure most on here have.
He was not to long ago now nobody knows but we all would love him to come back on and chat things throughIs this guy on here?
He's on here under different names trying to troll because he took the huff that we outed him as a top class bellend.He was not to long ago now nobody knows but we all would love him to come back on and chat things through
Yup for some fine tuningHe was not to long ago now nobody knows but we all would love him to come back on and chat things through
Yes unless on artex or backgrounds that need dubbing out with first coat or silk paint...
Its not as good a finish as a fresh 2nd coat once shrunk back but good enough to get paid
The wall doesn't know if it's a fresh batch or not.
The same amount of material is going on I could do a wall with fresh laying in gear and one with the same mix and there would be no difference at all mate.
Has anyone tried half a coat before?
A bit less than one
Lol
On the one coat did you use a spongeWe started 1 coating on site with the big 75ltr buckets 1 each and the quality dropped, striping and water marks.
I got the spot board back out and went back to basics
First coat
Flattern
Second coat
And so on
My work immediately improved.
I will lay down with same gear on small walls but will always flattern first.
no mate, we got lazy and were chasing a very poor rate.
not scared to admit the work was shocking and we got pulled a lot.
we'd bang an area on and turn back and lay in straight away, it didn't work for us, knocking gear back up sets it off flashing so that was no good.
work improved 10 fold after i went back to basics, but the other guy i worked with persisted in 1 coating and eventually we parted.
FreeYes unless on artex or backgrounds that need dubbing out with first coat or silk paint...
