It just seems there is no consisernt with multi half a wall needs different approach will that's who I find it lately then you see pics of scottie work and then I think what going on take my hat to spreads like that who bangs loads on and still that's that kind of finish
Would imagine if you site bashing pretty consistantly on fresh board it would be easier to get a good solid finish all the time. My finish on board dont look like scotties but is pretty good and uniform I think i tcan just be a bit trickier on all the manky reskim substrates....did some walls on friday and after 3 coats of pva was still pulling pretty bad...i had to give it a fair bit of water near end and imagine that wont dry looking the best...was defenitely flat and smooth though so will paint up fine.It just seems there is no consisernt with multi half a wall needs different approach will that's who I find it lately then you see pics of scottie work and then I think what going on take my hat to spreads like that who bangs loads on and still that's that kind of finish
Scotties spoilt in site that's what it isWould imagine if you site bashing pretty consistantly on fresh board it would be easier to get a good solid finish all the time. My finish on board dont look like scotties but is pretty good and uniform I think i tcan just be a bit trickier on all the manky reskim substrates....did some walls on friday and after 3 coats of pva was still pulling pretty bad...i had to give it a fair bit of water near end and imagine that wont dry looking the best...was defenitely flat and smooth though so will paint up fine.
I have one trowel I've had from the start, I never cheated on anyone in my life! And now it's all over for us...
What's the method mate? I'd like a nice spare for when the worst happensWhat kind of trowel do you use Jess, Beddy shared his famous breaking in technique which I have tried and it's a game changer, bought a new mt and had it worn in an hour.
Cheers mate really good info and thanks @beddy as it comes from him...i got a new mt already so will get this stuff and give it the treatmentI use a very basic version of Beddys technique, he uses Japanese waterstones a set of 5 I think which are in decreasing levels of grade , a bit like this ..
I just have a master class whetstone but has worked well for me so here is my set up..
A whetstone, piece of smooth slate (preferably Welsh slate) and a barbers strop
Soak the stone until bubbles stop and sharpen the blade starting on the rougher side of stone then work it on the smooth side, then work it on the slate and finish on the strop ( a blob of chromium oxide will help here) whole set will cost about £20 and process will take about half an an hour to get a new trowel nicely worn in, if using a carbon Steel which will produce a sharper edge then soak in vinegar afterwards, this will create a forced patina and make the blade black stopping any orange rust. Thanks to @Hicky for the vinegar technique
Marshaltown. Awesome read there thanks!What kind of trowel do you use Jess, Beddy shared his famous breaking in technique which I have tried and it's a game changer, bought a new mt and had it worn in an hour.
LolJust get the trowel out an use it beddy is telling porkies i send him my worn in trowels
Can you send me oneJust get the trowel out an use it beddy is telling porkies i send him my worn in trowels
How many miles are you putting on?Its true i usually break a trowel in within a day just using it
You are a true gentJess i got a nice 14 x 5 worn in that i don't use if you want it no charge just happy to pass it on
Na, jess can have the one I wantedCan you send me one![]()
If Jess don't want it i will send it to you mateCan you send me one![]()
You are a true gent
Enough it's the metal on metal that breaks it inHow many miles are you putting on?
