Ok, just about to install the bars. Would I be right in saying these can't be double sheeted as they seem very flimsy.
Cheers for that, using 100mm knauf acoustic roll but can't help thinking I'd probably get the same sound resistance with 200mm of normal stuff. If the acoustic roll was 200 I'd understand but can't get my head round it. @Runswithscissors whats the difference?Lol we thought that when first encountered but they are designed for soundnloc double boarding so no problem plenty of screws and the right size screws is important if they go into the joist you might aswell have not bothered
What size screws you recommend?Lol we thought that when first encountered but they are designed for soundnloc double boarding so no problem plenty of screws and the right size screws is important if they go into the joist you might aswell have not bothered
Thanks for that rich. I've installed the bars already. I went with 100mm knauf acoustic, the bars then double sheeted soundbloc. I was just curious as to why the insulation was only 100mm when I could have fitted 200mm of normal stuff in.Have a look at this page of Knauf Drywall Technical FAQ's
https://www.knauf.co.uk/technical-assistance/technical-faqs#q13
One is called - What is a resilient bar and how do I use it?
Might help....
Good luck!
Just the lads on here...Think that mix of board, insulation and space is the best way...... Has someone advised you what to do?
No the sameWhy can't you just mute the to for the 30 seconds it normally takes?![]()
My Mrs don't make a noise anyway so is the same for me,probably makes a lot of noise with a load of other blokes though lolNo the same
Any update on on the snooze block.. Interested to see pictures and know if she could hear you anymore Stu mate ?
Spot on mate,I had a few ideas for the lounge and love shack if you like purple and red bro ?
Main issue as you will know I'm sure is not to accidentally fix the flexible part of the bar to any batten or metal /wood stud hence yes creating a static point .If the insulation touches the bars does that render them useless?
The whole ceiling if installed correctly will flex on the bars and therefore absorb vibration/sound lights mounted should flex within ceiling and unless you have soundproofed walls as well then noise leakage through any openings i.e. Light fittings would be less I think than transferred through walls. You are reducing noise not eliminating it again there are systems for lights and door frames/doors etc all transfer noise to a degree.There are 8 downlighters going in the ceiling so I presume that will affect it as well?
Some good points there also worth mentioning if someone is thinking of soundproofing a wall on a semi detached house don't just think throwing up a stud wall with insulation and sound block will block say the t.v noise from the neighbouring house sound travels up and over it straight by passing the wall .. The ceiling defo needs to be done as well to get maximum sound block tbh I learnt the hard way on these there is more to blocking that sound than just boards.The whole ceiling if installed correctly will flex on the bars and therefore absorb vibration/sound lights mounted should flex within ceiling and unless you have soundproofed walls as well then noise leakage through any openings i.e. Light fittings would be less I think than transferred through walls. You are reducing noise not eliminating it again there are systems for lights and door frames/doors etc all transfer noise to a degree.
Not many know about the sealant but it's spec for all systems in the white book it's a little green dot and gets over looked it has to be done because of quality insurance and what they like to see is it around the system not underneath it again cos of quality assurance comes round and they don't see it they will ask you to take it up if you say it's underneath more of a get out clause than anything in my opinionMain issue as you will know I'm sure is not to accidentally fix the flexible part of the bar to any batten or metal /wood stud hence yes creating a static point .
Any boards or insulation again as long as not touching any edges of walls (unless also insulated for sound)so again edges to walls or pillars to be sealed with mastic to create flexible seal not transferring vibration ( noise).
I'm sure spec on ceilings is bars all running in one direction bar the last inverted. Maybe check on that as was 2 yrs ago since last one I did.
All info is found online.
Was you watching them how to videos on plastering Dan?When I did my place I made the loft room as sound proof as I could because I watch TV late up there and also work till the early hours and am often recording videos or editing them so being able to do that while jane sleeps in the room below is good.
Also when the time comes and we want kids I need to be able to shut the door and have some peace and quiet...
We used the knauf stuff ad spent about £5k but had been worth it
Bg have changed there screws now to one screw does all they have got rid of timber screws and a few sizes maybe get a box of the size you require could make it easierAn update on this, those bars are a fking nightmare to screw into. The boards being heavy make it hard work and using course thread screws aren't helping me
For first board it's 25mm so you don't screw into joists by mistake but because the bars only have a fixing one side if you screw too close to other side the bar lifts and the screw doesn't bite. If you put pressure on and screw fast once it does bite it disappears through the board lolBg have changed there screws now to one screw does all they have got rid of timber screws and a few sizes maybe get a box of the size you require could make it easier
You doing on your own?For first board it's 25mm so you don't screw into joists by mistake but because the bars only have a fixing one side if you screw too close to other side the bar lifts and the screw doesn't bite. If you put pressure on and screw fast once it does bite it disappears through the board lol
Two of usYou doing on your own?
