Cockney
Ive been preparing a nice dinner for her today when she returns from rock wooling and boarding the hall ceiling.
which came firstSorry I stand corrected its 1800..too much coke and s*x last night so im abit hazy
So it is bent all over the shop then lolI've got a life ritch its bad enough I come on here let alone taking pics of speedskims and putting on here.just isn't my bag.you carry on doing your way i couldn't care less
I've left mine on site , dead flat , do pic tomorrow and you can laugh at the buildup of muck lolSo it is bent all over the shop then lol
I wouldnt bother wasting your time you cant explain to somebody how to use them,just because they can't use them they think knowbody canI've left mine on site , dead flat , do pic tomorrow and you can laugh at the buildup of muck lol
( same as my trowels )
I've been strictly ss all the way through ( no water apart from brushing angles ) I tell you Rich it's a game changer , I wouldn't use it if the end result was poorer quality
Trouble is I don't put more on , just do more coffee lol
I think the problem is people shortcut the laying on flat and expect miraclesI wouldnt bother wasting your time you cant explain to somebody how to use them,just because they can't use them they think knowbody can
Theres things I cant use like spats there just not for me but I don't know how to use them,dsnt mean there s**tI think the problem is people shortcut the laying on flat and expect miracles
I pulled it all off with mine so I chucked it in the binI think the problem is people shortcut the laying on flat and expect miracles
I'm quite getting the bug for trying these different things , I've only got a 1200 and been on mainly overskim so it's a bit long to go with the flow to be fully effective but makes life simpler for sure. The odd new board work I've had it's a blessing.Theres things I cant use like spats there just not for me but I don't know how to use them,dsnt mean there s**t
What bin ?I pulled it all off with mine so I chucked it in the bin
I just pulled mine off and shot my load in the bin
Get the 900mmI'm quite getting the bug for trying these different things , I've only got a 1200 and been on mainly overskim so it's a bit long to go with the flow to be fully effective but makes life simpler for sure. The odd new board work I've had it's a blessing.
Looks neater than when I've finished it with a trowel
I'm too tight lol may get some 1800 and chop it upGet the 900mm
A speedskim is nothing near as flexible as a spat or s*p*r*lex trowel mate.For clarity what im trying to explain is forget sizes for a minute.
If all were 600mm for example then why would flattenig straight away with a s*p*r*lex be any different to a speedskim or spat in that there all blades with flex.
You recon?...see i would have thought the opposite!A speedskim is nothing near as flexible as a spat or s*p*r*lex trowel mate.
Well I've had Nela flexy trowels and Eze spats and they're definitely more flexible than the speedskim.You recon?...see i would have thought the opposite!
I recon if i run a speedskim over a wet wall i would take less off rhan if i tried same with a spat or flexi trowel?
Me to pal@zombie I am talking about the plastic speedskim blade, I've never had the metal one.
Hang a small weight off the edge of both and see which deformed the mostA speedskim is nothing near as flexible as a spat or s*p*r*lex trowel mate.
Mine certainly aint like that,does it matter your not running the speedskim edge square against the wall ur placing it on on a angle so all touches,but tbh yours look shagged
Bores me to death.like people putting skimming photos upDon’t you get bored talking about spats plazi b*ll***s! Just get job done get paid go home get pissed shag ya mrs or boyfriend or gender neutral partner that neither identifies as male or female non binary person![]()
We use thincoat spats not sure what they are tbh must of had em 10yrs could scrape a floor with em if you wanted so im guessing a thicker gauge than eze spats?
Yes they do sound much stiffer than an Eze spat.We use thincoat spats not sure what they are tbh must of had em 10yrs could scrape a floor with em if you wanted so im guessing a thicker gauge than eze spats?
Are you confusing 'overkill' with 'do a decent job' again you slag? (read 'slag' in cockney accent)I used to use speedskims mate
put it on flatten it
then speedskim it still wet.
then trowel it again it would unflatten what the speedskim did lol
so speedy it again
few cross trowels it turned out nice ....
to me it was over kill.
used to like them though![]()
I used to use them 600 spats they are a lot more rigid than a flexi blade i can't use them anymoreWe use thincoat spats not sure what they are tbh must of had em 10yrs could scrape a floor with em if you wanted so im guessing a thicker gauge than eze spats?
So what do you use now?I used to use them 600 spats they are a lot more rigid than a flexi blade i can't use them anymore
so speedy it again
Ye but uve got more times to do other things.why would you want to flatten a 30m2 lid with a trowel young man? Speedskim twice then medi and super..job doneDo you know what mate thats exactly what i find i think there better to just use right upto wet trowel or you undo what you did before.
But then i think ffs i only used to trowel the wall 3 times with a mt then go back in room once going dark for a dry trowel so felt like touching walls to much
