JessThePlasterer
Queen Jess Elizabeth I
I don’t get it... I can see where I’ve pva’d Because it’s darker/shines in the light. I’ll pva tacky if there one day or pva and skim dry next day all depending
If you put pva on, food colouring or not and it drys, and it has runs that set it does bleed through skim, key is put it on when tacky when using food colouring.I don’t get it... I can see where I’ve pva’d Because it’s darker/shines in the light. I’ll pva tacky if there one day or pva and skim dry next day all depending
Food colouring is safe to use, but don't pva and let it dry, when painted the emulsion paint was not penetrating because pva had set. Skimming is applied on tacky pva, it says on container, if you do dry then your changing spec.Just brush through all the grit dust and shite on the wall as you go then it’s easy to see where you’ve been
Tbh my eye sight isn’t as good use to be mate and often work in dark rooms just thought would make my life easierSame. I’m also systematic with it so impossible too miss anywhere even if did it with the light off.
The problem is pesky labourers
No, certain brands of pva do not emulsify now. pva has come on quite a bit now, with new additives now if you research it if interested.But dry pva re-emulsifies when wet skim hit it?
U not got lights for dark rooms. LolTbh my eye sight isn’t as good use to be mate and often work in dark rooms just thought would make my life easier
Would not matter one bitFood colouring is safe to use, but don't pva and let it dry, when painted the emulsion paint was not penetrating because pva had set. Skimming is applied on tacky pva, it says on container, if you do dry then your changing spec.
I didn't say dry won't work, but spec of pva is apply plaster when tacky not dry. So you ain't following application instructions. So if there is a fail of bond that could be a possible cause. If it works for you that's good. As the food colouring process I do, has never grinned through.The emulsion only has to penetrate the skin nothing else the food colouring was grinning through not everywhere just in places and the ceiling would be on the deck by now if skimming on to dry pva didn't work
Waterproof pva, once dry.I don’t understand how it would work if it didn’t re-emulsify when skimmed.
Would your skim be resting on a thin layer of dry pva?
It's in my own house mate I don't work in people's houses and never willI didn't say dry won't work, but spec of pva is apply plaster when tacky not dry. So you ain't following application instructions. So if there is a fail of bond that could be a possible cause. If it works for you that's good. As the food colouring process I do, has never grinned through.
Whys thatIt's in my own house mate I don't work in people's houses and never will
Whys that
I prefer siteworkWhys that
No its notWaterproof pva, once dry.
I'm not saying that's what you used, I'm saying to lurpak, you also get pva that's waterproof once dry. They do not all emulsify.No its not
They are many different kinds of pva lurpak, that can be used for different construction, some not to be used for skimming.
Oh yes, lolDefinitely mate, assumed we were talking about ones that conform to BS 5270/plastering
AnorakDefinitely mate, assumed we were talking about ones that conform to BS 5270/plastering
Car
Carl the plasterer will say you learned that on your course haha
Rather predictable ent she
You make it too easy for them mate bitch be on soon too
