Baptist2017
Like it’s a game for you? LolIt’s almost as if I’m pulling the strings isn’t it
I have NEVER skimmed dry PVA , not saying it wouldn't stick bit it's not as good bondFood colouring is safe to use, but don't pva and let it dry, when painted the emulsion paint was not penetrating because pva had set. Skimming is applied on tacky pva, it says on container, if you do dry then your changing spec.
A tight skim over dry PVA runs a greater risk of delaminating when mist coating .
I don't patch and feather out , its patched then when dry is blended with toupret filler
Lol , your right of course , if I ever say " that'll do " , I'd pack it inEvery job you say seems backwards and hard work. But fair play if it works for you pal
Spent first 10 years sand/ cement/ lime , my dad would skim it , ( i always said skimming was poofters work ) , had a bad run with external render ,weather and a couple of builders going tits up and claiming bankruptcy so took the plunge and learnt to skim on my own , PVA was always skimmed wet or tacky , said that on the tub , so after 30 y overskimming it's second nature and causes me no problems to hit it tacky .Dry pva club here never an issue. Only skim tacky if absolutely have to. Pva first its usually dry in 20 mins (decent pva)
If PVA is OK to skim dry why did they bring out the grit
You make it too easy for them mate bitch be on soon too
Yeah makes no sense does it, charge the maximum amount for the best job you can do. Ridiculous
Biggest load of b*ll***s I’ve read on here in a while. Ffs! Coloured p.v.a! Lol.
In the words of an much respected ex memberI was always taught skim when tacky, then I read more and more posts on here about dry pva re-emulsifying and joined the club. Haven't used grit since. On a very glossy surface you can peel grit off sometimes too. Oh yes you can.
Lol can’t beat the blue grit is that you on your profile pic?i thought I’d reckonised you from last months episode of crime watch..you still on the run mate?Bit of blue grit in to dye it that deffo wont bleed
Have you tried food colouring, or paint or anything else ?
Want to really brighten up my pva
Putting white pva on white silk painted surfaces, it is reasy to miss bits, it is a aid and a bit of piece of mind all the surface has been covered with adhesive. Simple, and this tip was on this forum years ago, not by me. Not expensive either, applied correctly and wipe any splashes off any uncovered surfaces then easy. Grit has pigments as said that don't bleed through. Do not apply too thick and allow to dry then you could have bleed through, I have never had it.I tried it today not gonna comment yet until I see it painted ok
If looks ok I’ll thank @Donzo
If it bleeds threw I’ll blame donzo
I’m the same mate have always skimmed over tacky pva I was always thought to go wet on wet so pulls in together..everyone does it different..Spent first 10 years sand/ cement/ lime , my dad would skim it , ( i always said skimming was poofters work ) , had a bad run with external render ,weather and a couple of builders going tits up and claiming bankruptcy so took the plunge and learnt to skim on my own , PVA was always skimmed wet or tacky , said that on the tub , so after 30 y overskimming it's second nature and causes me no problems to hit it tacky .
@LarryTheLag which one did you use to make a mould of your b*ll***s?
Pure finish, gets right in the creases and pulls off quite nicely
Don't forget to pva first
with gorilla glue
My last one didn’t turn up. Could you send another plz
it'll have hair and scabs in - that ok?
No, certain brands of pva do not emulsify now. pva has come on quite a bit now, with new additives now if you research it if interested.
Same thingSorry I meant 'whack'
