ChrispyUK
Sbr on Amazon, everbuild £15.
Yeah, bought last one off eBay - about £14-£15
@Olican , why do you use a mix other than just PVA
Did you 2 coat , expect it to dry quicker , prefer to skim on tacky but would use on high suction overskim for first coatI find I get better coverage with it, hard to describe but it seems to have more body to it. When coating higher suction walls it seems to resist the suction. Also find skimming over it goes in lovely. Did a big ceiling today , very old bare boards that normally pull in too quick, especially into edges. Went in lovely
Depending on background wether I 1or 2 coat.Did you 2 coat , expect it to dry quicker , prefer to skim on tacky but would use on high suction overskim for first coat
I will in a bit but I’m not rushing just to satisfy your fantasiesLet's see some photos of ya pva tubs . Ooh I can't wait.
Shall we call that two then?Depending on background wether I 1or 2 coat.
Even if I one coat I'll go over again but just with roller to make sure no misses
Same ! had patches come away from the wall in a stairwell One day vowed to never use again shocking stuffhad failures with that shite.Can get evo stik for same money from certain suppliers and its the besttttt
Bought one of these today after seeing this. Had always used Wickes before as was to cheap to turn down but definitely false economy. Diluted this 2 parts water, 1 PVA and still thicker than Wickes at 1/1. Went on nicer, dried quicker, and plaster troweled up nicer and easier than has done in ages. Now to buy a job lot.
Did you skim it dry ?The last wickes PVA I used I pretty much used it neat... I have used @Olican SBR mix before and it skimmed lovely...
