kebab king
Ginger mt
You still got that fishing gear for sale mate?Ginger mt
1was latexing some floors the other week which came with an acrylic primer, it seals the floor and dries in an hour but, and this is the but stays tacky to receive the latex,
whats artex sealer for...................:RpS_confused:
For sealing plaster & plasterboard before you artex it marra :RpS_wink:
Oh fook it jusy board it ffs![]()
Used to reduce the porosity of the backing substratewhats artex sealer for...................:RpS_confused:
YellowWas it blue?
close the windows in the room your workin in its prob a breeze hittinhg the ceilingI started with a 50/50 pva water as usual 2 coats then spread when tacky, but these ceilings are just sucking the lift out of it so started using a stronger mix but its just not helping what so ever..
out of the 6 ceilings I've done 4 have flash set and 2 have hung for 4 fckin hours!
Each have had the same treatment..
notice it's only the ceilings btw Walls have been fine..
Lol it's not the windows..
funny how everyone jumps on a question an starts presuming they know it all..
I bow down to the almighty knobheads.
personally I couldn't give a crap what half of you think..
I asked a question half of you wouldn't in fear of being reprimanded grow up men!
:RpS_laugh:
spanky trust your own judgement, go through all said pva's , wba and solutions and find wat works for you, everybody as there own preference and mine is wba mixed with 4.1 pva but leave it longer before skimming . Good luck finding one that works for you .
p.s be confident in your ability !
Is there lots of insulation resting on the ceiling above? + hot day can make it go quick.
I never bother with Pva these days why do it 3 times when you could do it once with blue grit or similar.
spankster you big homo, get ya sel in the G** section or k there is room in the dummy spitting section with Beddy..................:flapper:. anyway on a more serious note anyone know what artex sealer is for .................:RpS_confused:
after you have taped up and caulked out the joints in the plasterboard, you give it a coat of artex sealer to give you an even suction for the texture coat.
If it really high suck spanky ,,, don't think blue grit is your friend? Try using sbr if the background is dry as a nuns **** .This is exactly what I was asking for, I have used blue grit once but it's the waiting 24 hours that puts me off using it, but would have used it if it would have stopped the flash sets..
Never really thought about the insulation holding the heat in could well have been that..
No way of remedying that
I'm gonna give that artex sealer a try.... I never knew what it was for...:RpS_unsure:thank feck. arti. asked.:RpS_lol:
