D
Deleted member 29624
Guest
Someone wants me to block a couple of doorways with studding, everytime I see one thats been done a while its always cracked, any tips on the best way to stop cacks coming around the edges.
Thats definitely how I would do it, would never skim over the timber but presumed they were cracking anyway just becuase the studding expands and contracts a bit with heat etc and the solid wall doesntTake the door standards out and build your frame back enough to fit your boards flush and butted up against the existing plaster.
Then your not plastering over the timber then grttin a crack all round the old opening....
My block work aint the best mateIf it's solid use blocks mate she scrim the edges
Doesn't need to be you'll plaster over it!My block work aint the best mate![]()
That makes senseBest way if you timber partition!
Screw your pb
To timber as usual, go past opening with board , that edge is fastened with adhesive onto solid wall
Just stud them. Stick paper tape around the frame wth PVA and then skim. f**k me.Someone wants me to block a couple of doorways with studding, everytime I see one thats been done a while its always cracked, any tips on the best way to stop cacks coming around the edges.
Lol...i want it to stay crack free forever though....especially as I know the bloke im doing it for so it would get mentioned at some pointYoul be paid a long time before it cracks!
Buy her some constipation medicineAsk my mrs, her backdoor is a blocked area ffs
I given her some laxative but the s**t came out of her mouth, you wouldn't believeBuy her some constipation medicine![]()
Happy days, everyones a winnerSo will I now..and charge more.![]()
Screw your pb
Yes will be skimming the whole walls so not an issue on that frontAs blackdog said I would paper tape the join and if the walls are not too big or awkward skim the whole lot, they will never know a door ever existed. Must admit I've been impressed with the BG fiba tape with tight weave it seems strong.
Sent from my Nexus 6P using Tapatalk[/QUOT
Use metal stud![]()
Metal stud is a great job. Just uk and Ireland that still using timber studs![]()
That's what I do. Scrim round edges only will nearly always crack. No shortcuts.Best way if you timber partition!
Screw your pb
