Bostick plastering stabilising primer ( grit)
Are you going to give a refund for the full cost, if the background passes the grit test tape but then the work fails?
Forgot about backgrounds, all the green grit is stuck solid on the backgrounds, delamination occurs on the grit.
It's the grit that plaster has not fused with.
I
Not disagreeing mate. It’s just not infallible…although what is. I’ve had a few issues with it too.
i haven’t had problems with it so far,but as someone said it probably dried too quickly.
Went over some blue grit last week and that was horrible to get over,
Had to put a base coat of skim to get over it the day before.
Still prefer the WBA.
I
Only issues I’ve had holly is akin to blebbing over bonding.
I
Blue and white striped grit?
