The Apprentice
Was anything stuck to the back of the grit?
I asked bostick to come out and test it but they didn’t want to know!!!
I don’t dilute anything and don’t cut corners but the manufacturer will always find something they can blame the tradesmen forGrit or should I say Bond-it, bit of brand loyalty here, is designed for glossy surfaces, from silk paints to tiles. So provided that area is clean it should adhere to it but it must be clean and dust free. If it fails on the substrate you can at times see dust etc on the back of it.
Failures with plaster are predominately due to not mixing it up enough so not enough aggregate in it for the plaster to grip to. Of course it can be applied to thinly which again is a lack of a mechanical key, so not a good idea to dilute it with anything.
If you’re going over it with Bonding coat the depth should not exceed 8mm.
Failure to use any product as per the manufacturer instructions and it’s all on you. Yes it might cost you a bit more time and money but you need to cheat on a lot of jobs to cover 1 fail. Even the PVA manufactures can check the strength of the PVA you used, is it worth the risk? That’s for eac of you to make that call.
It can be a bit harsh internally as it’s a strong smell but nothing else comes close. It’s designed for render so can definitely hold skim.I’m going to buy some. 20kg tub is around £60 so works out about the same as the cementone.
And a finer, nicer to skim over grit that most of the products that are designed to be skimmed.It can be a bit harsh internally as it’s a strong smell but nothing else comes close. It’s designed for render so can definitely hold skim.
no mate. but it never has in over 18 months and thousands of beads.So if plaster shells off your tape but no where else your not liable??
You can carry out an easy test for grit suitability using my tape. Stick a strip to the wall and leave for a few mins. If it has not stuck to wall then prep wall. If it has stuck well pull away sharply and check paint is still adhered to wall. Grit test tape, I might patent the idea.I’ve heard about the smell during my bit of research about it but apparently once it’s dried it’s ok. Dunno tbf as I’ve never used it.
I’ve potentially got a job coming up over skimming a number of rooms in an ex council house after my mates done the rewire but house is empty. Should be a good test bed for it.
First time for everything, like me with the grit job that went tits upno mate. but it never has in over 18 months and thousands of beads.
No just flaked offWas anything stuck to the back of the grit?
Personally I don't dislike the smell. Certainly no worse than me after thirty metres of screeding.I’ve heard about the smell during my bit of research about it but apparently once it’s dried it’s ok. Dunno tbf as I’ve never used it.
Same. Blue Grit is ridiculously large aggregate for a skimming product, even worse than Bondit.That’s what annoyed me about blue grit and why I started using the Bostik stuff.
Strange one, the only thing I can think of is grease or something like that but only guessing. Got to say I’m surprised that they wouldn’t test it though.No just flaked off
Definitely not grease!!Strange one, the only thing I can think of is grease or something like that but only guessing. Got to say I’m surprised that they wouldn’t test it though.
Why do you use grit bond? All i ever use is PVA. in UK.I’ve used it for years too ,
But no more
do it properly you need to give it 3 coats !!! And pva is no good on a silky/glossy wallWhy do you use grit bond? All i ever use is PVA. in UK.
I did use the red and green grits in the Netherlands as that was what they supplied but I find PVA easy to use ,less to cover and I have never had it fail.
Great advice on PF. I've just done a refurb upstairs of an old pub and used bond it plasterers pre grit on 2 coats of SBR 4-1ish, had no calls yet!anyhow, sat in me kitchen half cut, curry bubblin watching possibly one of the greatest films ever, hot tub time machine..! Have a good nightGrit or should I say Bond-it, bit of brand loyalty here, is designed for glossy surfaces, from silk paints to tiles. So provided that area is clean it should adhere to it but it must be clean and dust free. If it fails on the substrate you can at times see dust etc on the back of it.
As Andy says micro is good stuff but states only water down 10%. I was paying £46 inc vat for it last year but its now around £64, as ive had no failures ill keep buying it and Accrofix ( PRB alternative) from p1shop cheltenham.I don’t dilute anything and don’t cut corners but the manufacturer will always find something they can blame the tradesmen for
I’ve another one to do next week!As Andy says micro is good stuff but states only water down 10%. I was paying £46 inc vat for it last year but its now around £64, as ive had no failures ill keep buying it and Accrofix ( PRB alternative) from p1shop cheltenham.
Is accrofix any good? Was gonna order some but @p1ss want 50£ deliveryAs Andy says micro is good stuff but states only water down 10%. I was paying £46 inc vat for it last year but its now around £64, as ive had no failures ill keep buying it and Accrofix ( PRB alternative) from p1shop cheltenham.
Is accrofix any good? Was gonna order some but @p1ss want 50£ delivery![]()
Yea its good stuff and delivery is down to it having to go on a pallet i think. Its not too far from me so i go over and get 3 or 4 tubs at a time.Is accrofix any good? Was gonna order some but @p1ss want 50£ delivery![]()
No mate p1shop cheltenhamWalls and ceilings?
Ive looked at the spec sheet and seems very similar to micro except adding 5 litres of water!I’ve been using VPI Accrolor2 …. Seems very good. Just like Micro was……
Just had a big ceiling fail with this s**t !! Grit is completely adhered to the artex but the Skim has come away clean , how the f**k is this sold as a bonding agent ,never had a fail with bluegrit, spoke to a couple of spreads I know both had ceilings and walls fail on greenDONT USE !!!! Had a major fail with this rubbish and bostick technical guys don’t want to know, cu nts!
Hate that blue grit I use sovereign never had problems but there again is any grit 100% guaranteed regardless of the manufactures bullshit nothing more safter than overboardJust had a big ceiling fail with this s**t !! Grit is completely adhered to the artex but the Skim has come away clean , how the f**k is this sold as a bonding agent ,never had a fail with bluegrit, spoke to a couple of spreads I know both had ceilings and walls fail on green
I think when it fails on green,it looks as if its dried out too quickly on it.Just had a big ceiling fail with this s**t !! Grit is completely adhered to the artex but the Skim has come away clean , how the f**k is this sold as a bonding agent ,never had a fail with bluegrit, spoke to a couple of spreads I know both had ceilings and walls fail on green
Are you going to give a refund for the full cost, if the background passes the grit test tape but then the work fails?You can carry out an easy test for grit suitability using my tape. Stick a strip to the wall and leave for a few mins. If it has not stuck to wall then prep wall. If it has stuck well pull away sharply and check paint is still adhered to wall. Grit test tape, I might patent the idea.
