Bullnose beads
for a very short time ,years ago, we used a bullnose angle trowel and a bullnose twitcher.
people did not like the windows in bullnose it looked to much like a tv screen, which were rounded at the time.
the bullnose internals were a problem for the carpenter to fit skirting boards.
You get a lot of old bullnose internal that transition into a right angle at the bottom.
I’ve got to agree with gibbo. Stop beads a stop bead. A bell bead is a bell bead. I’ve never asked for a stop bead hoping to get a bellcast.
  • Agree
Reactions: Djr
Have a look at the link at the end of the last page, it’s a render stop bead not a stop bead if that makes sense
Whats the crack with these just been told all the windows are having these was going to put a normal bead on the head the the 2 on the sides would this look right anyone got any pics thanks
If you cut the bead with a miter saw you can get very tight joints. If you don't want to use one of those you can get by marking the bead with a speed square and cutting it by hand. Personally I don't mess with the bead much unless u have to and just do them by hand using a bullnose corner tool. My favorite radius side is 1/4" but have done everything from 1/8 to 3/4 and it works great. (Very straight and consistent with a little practice and base coat)
Here's an example from last week.
  • Bullnose beads
  • Bullnose beads
yes that was a birds beak angle.
the ones we did were just bullnose internals, to float and set a 2 bed bungalow we got £35, so you had to jump about a bit !
Cheers for that, you learn something new everyday, I had no idea that it had name.
