billcarphead
hello all
having a bit of a problem with a newly plastered ceiling, every joint has opened up hairlines down the board's length and some wider ones on the width joints.
The ceiling screwed up tight (no popped heads) fibre taped every joint tapered edge boards 2 coats of multi 2 separate mixes. 3.4 w x 5 ish .
clearly shrunk in my opinion client saying no heat was put on, but its the room with the only sky tv.
Boards came from Wickes to the job in 10 min no rain. (possibly Knauf sending out boards with maybe higher than normal moisture content ??(in these lean times money to be saved there) but is anything sounding familiar here?
The leccy turned up as we were finished and clearing up to pull lighting cables to the 2 ceiling lights (apparently did this without needing to enter the room above the ceiling.
I've been to easifil it once now she wants it done again
does anything sound familiar, or seeing anything similar out there cause it's not making much sense to me.
Thanks for any replies
