Try polycell crack free ceilings. Flexible paint. I carry a tub round in van and leave a little bit sometimes for customers to put on as base coat around stress points where I know it'll go. They love that touch. Just filling will mean crack returns. I skim a lot of artex. I rescrew joists where currently cracked and then use render mesh. Having fantastic results with that method, but yes, get the odd peeler now and again. Artex stabiliser is good prior to Pva or sbr if looking iffy (I know it's hard to tell) could write a book on trials and tribulations of ceiling hairline cracks.
[/QUOTE good advice mate thanks . From someone else who has had the odd peeler. Why do most spreads on here automatically just say things like “ I always bond over artex first and I’ve never had a problem. Well you’ve not down enough then if you’ve never had a ceiling bleb. You can never tell which way there gonna go .
Paper tape is better but shrinks. I get on day before to stop the shrinking which shows through. Been over a year since I've used though.. How do others apply paper
Yes, that's always confused me. Those that also say.. "I've never had one crack, you're doing it wrong" And to those I say "yes, you have, really, you have, now stop being a silly billy and lying in public" ...If you started a thread asking if anyone had ever dropped a bit of plaster whilst skimming you'd get someone saying " no mate you're f**k**g useless, call yourself a spread"
Someone once told me criticism is the easiest thing in the world
Not from artex though?You have to presume all artex ceilings pre 90s have asbestos in them. We have been told when over boarding to use small drill bit to find Center of joists, first spraying a drop of shaving foam on area to be drilled. When over boarding same process spray foam on point where fixing screw, then wipe off foam. Fp3 masks, over shoes or duck tape shoe laces, disposable overalls. Charge them for it, why cut corners to save customer a few quid. More to the point why take it home on your clothes for your kids to breathe it in.
I've seen it kill 3 people all of them in their early 60s.
You think that there would be an epidemic of guys dying of asbestosis given the amount of artex that was applied over the decades not to mention all the artex thats been recovered. Is there any evidence for such a thing.You have to presume all artex ceilings pre 90s have asbestos in them. We have been told when over boarding to use small drill bit to find Center of joists, first spraying a drop of shaving foam on area to be drilled. When over boarding same process spray foam on point where fixing screw, then wipe off foam. Fp3 masks, over shoes or duck tape shoe laces, disposable overalls. Charge them for it, why cut corners to save customer a few quid. More to the point why take it home on your clothes for your kids to breathe it in.
Over the past 20 years I've heard "be careful with artex, it contains asbestos" and "don't worry about artex it contains only a small amount of relatively harmless white asbestos" . I don't think anyone really knows. Have British gypsum ever given advice on its artex pre-90s?You think that there would be an epidemic of guys dying of asbestosis given the amount of artex that was applied over the decades not to mention all the artex thats been recovered. Is there any evidence for such a thing.
I think they removed the asbestos at some point, not sure when but for some reason I have 1990 in my headOver the past 20 years I've heard "be careful with artex, it contains asbestos" and "don't worry about artex it contains only a small amount of relatively harmless white asbestos" . I don't think anyone really knows. Have British gypsum ever given advice on its artex pre-90s?
If I remember rightly there was the artex branded one in a white bag and stuff that was called contract in a a brown bag.Asbestos firm turned up at a job i was on. I was skimming the ceiling id just scraped back too lol.
Had a chat with the bloke about it and he said basically IF there is any in artex its white and a small amount, he wouldn’t even be concerned about it.
It was tested and was free of asbestos as this was a pre90 build so its not in all artex.
He said it’s the old floor tiles that are more dangerous
s**t my house is 1960s and I recently tools up a load of those really thin black tiles off the floors. Is that the ones that’s gonna kill me ?Asbestos firm turned up at a job i was on. I was skimming the ceiling id just scraped back too lol.
Why is he gonna slip on them and break his neck?Yes mate, that’s them.
Who knows it's impossible to pin point a cause considering it can take 30 years to show up.Not from artex though?
A job some contractor's done cut into artex wall with chassing machine, customer knew it contained asbestos called in authorities had job shut down. Professional cleaners called in and got a load of compo. A massive headache.Asbestos firm turned up at a job i was on. I was skimming the ceiling id just scraped back too lol.
I have never heard that floor tiles were made from it.
You can normally tell they are mostly imperial in size slightly thicker and brittleI have never heard that floor tiles were made from it.
i took up the first lot about 15 years ago in lounge . They are like really thin tiles stuck down with tar . Any how I’m still okYou can normally tell they are mostly imperial in size slightly thicker and brittle
Take them up most weeks. They are thin compared to ceramic, but thicker than most vynl tile. They are normally stuck with a tar like adhesive but mostly they pop up quite easily, whole as well. Although I have come across a Marley type vynl tile that tested positive.i took up the first lot about 15 years ago in lounge . They are like really thin tiles stuck down with tar . Any how I’m still ok
tTake them up most weeks. They are thin compared to ceramic, but thicker than most vynl tile. They are normally stuck with a tar like adhesive but mostly they pop up quite easily, whole as well. Although I have come across a Marley type vynl tile that tested positive.
same here palI’ve got 9.5 years left .
If we worked in the pit we could claim for all this . White finger off mixing drill. Lung cancer from artex. Mental illness from Andy g. This list is endlesssame here pal
ive give up on andy think he is a wind up merchantIf we worked in the pit we could claim for all this . White finger off mixing drill. Lung cancer from artex. Mental illness from Andy g. This list is endless
