I have just over skimmed 6 ceilings in a house and have not guaranteed one. Explained why and they understood. As we were walking round the house when I went to quote I noticed the hsl lids were smooth but could tell by coving line they'd been over skimmed. They had a couple of cracks in. Glad they did because they proved I wasnt bullshiting them. Regardless of that they still went with the overskim options and I had it written in my quote and invoice that no guarantee was given.
i would have not given them the option of second reskim. remove cove overboard with the correct length screws, and skim and recove.
Unfortunate for you, I'm thinking that the owner relies on the 'Expert' to identify any existing or potential problems with the ceiling before proceeding with finishes. I never add a layer of board over existing plaster ceilings, too much liability with the extra weight in my opinion, and always check ceiling with a straight edge to see if any of it is hanging down also check all cracking to make sure areas are solid, if I suspect there are loose areas I just put the repairs into the bid. Throw some extra in for some repairs that are little surprises.
Well, my part of the world we always gotta figure in the fact that we get some pretty good earthquakes every ten years or so which will break the paper around the screw heads. If I'm putting up board it's only because I removed all the old plaster, and usually in that case they hire a gang of Mexicans to demo, hang board & tape and I don't get the job. For the last 15 years I have been embedding fiberglass sheeting into all purpose joint compound followed by up to three more coats letting each coat dry before putting on the next. There usually is a crown mould run around the room and this type of overlay strengthens the existing plaster and it also allows for little intrusion against any mouldings.Sometimes over boarding strengthens the ceiling. If you've got a fragile old lath and plaster ceiling, screwing up 12.5mm pb with 75mm screws through the whole lot into joists will be a safer bet than skimming on top.
I always check a ceiling with a level when I quote, it was as good as perfect. Not one single rack in the artex and no nail popping at all, it was even solid to push,
Suggesting over boarding in this situation would strengthen it? You would be screwing plasterboard to a 4.9 meter batten which only held up with five 40mm nails that support 5 sheets already, the weight of a skim coat brought it down, suggesting plasterboard and skim coat would have been a better choice issue just an over sight, I'd be very impressed if yous managed to tell me how many nails were used and how secure the battens were by looking at an artex ceiling regardless what checks you carried out, it's not the sheets that have come away it's the frame that separated
Its getting multi national on the forum these days :RpS_thumbup:Didn't notice you were from across the pond, I guess methods are different over there.
This is no longer a trade (in my area) that I'd recommend to anybody that wants to make a good living, because you're right, everything's gone drywall around here. We used to have around 400 + plasterers in the Seattle area when I was younger. Now the population has doubled and I don't know if you could find more than 150 of us around here now and most of them are clueless about anything discussed on this forum. One thing that has gotten me quite a bit of work has been figuring out how to make drywall match the plaster textures.I assumed Americans would go on a dry lining forum!
Across the pond and then some (7,700 kilometers). I like this forum because it's interesting to see the different ways you approach things in the UK. A lot of the terminology is different and I'd be lost in one of your material supply houses. Our scaffold looks a lot different than yours also.Didn't notice you were from across the pond, I guess methods are different over there.
I work mainly on "older" houses around here that were built from 1914 - 1958 after that most were built with sheetrock walls & ceilings and before that this area was sparsely settled and it's rare that you would find many of the buildings and houses still around that were built in the 1800's. Now days I'm never surprised that the general contractors I'm recommended to have never worked with a plastering contractor before.Nice one - most of jobs are traditional plastering as British likes traditional, drywall are only for factories / offices / buildings I guess. We use a lot of dot n dab and skim.
Hi Lucius, You're right I am quite specialized for this area, for quite a few years I was naming my price but I always tried to keep it reasonable, because I never wanted to alienate contractors who I do repeat business with. Having been in the industry for so many years I've witnessed quite a few economic ups and downs and realize how important those contacts are when things slow down. If you had purchased a house around here in 2005- 2008 you probably now owe more on the house than you could sell it for. So the recovery as been slow and long, luckily I get plugged into some of the high end jobs where the owners are wealthy enough that the economy isn't affecting what they spend on their houses. But with the crap economy they expect reasonable pricing, and with a lot of the "fill in" work not happening, things are pretty tough around here yet.How competitive is your work Loren? ie you are quite specialised can you just name your price within reason and get the job.
