Ianspreader
Hello what's best curved or flat marshalltown trowels? Also is duraflex much different cheers ian
yeh you said any pressure on a flat suface and it makes contact the full lengh aprart from both ends,what is its not a flat surface ? theyre far to flexable and bendyWell I don't know what was wrong with your Permashape trowel but those that I've used/use have been spot on. Yes they have the curve of a worn in trowel but the slightest pressure against any surface and it's making good contact along it's length barring the very ends, perfect.
Having said that most of my finishing is done with a carbon steel trowel.
tried a permashape pre worn marshall town once and once was enough , no point using a banana to acheive a surface flat surface but opinions vary. In fact ss sucks as far as im concerned but if its all you know rock on and have fun. if i were you id definately start the way i mean to go and use flat because these permashape things leave sub standard work..........................good luck:rolleyes)
The problem with a flat trowel is that they take an age to break in and then when they are broken in if you look down the length of them they are slightly curved. The permashape just makes it so you can use the trowel after a quick rub on a stone. Another benefit of the permashape is that you get a guarantee that they will not go the wrong way, something to do with the steel, and flat trowels can go the wrong way.
There seems to be a misconception regarding MT trowels. They are all Permashape, even the flat ones![]()
Sorry Minh but that's not right, they're not all Permashape.
Yer has a curved permashape for about 3 years good trowel now, ordered a flat one thou to give it a go
Lol if you can't get a flat finish with a perma your doing it wrong! Mines like a snooker table, it's how you put it on and flatten what counts
I find that twenty percent of them are no good, you have to check them for banana from time the come out of the boxMy old gaffa bought a permashape and took it back a week later. Had bent completely the wrong way.
Surprised that a trowel lasted thirty years, I used to wear a Marshall out in less then five,Have been using my old Tyzack double hang steel trowel since I was about 18 (I'll let you work that out) and it is bloody great. However, I purchased a new Marshalltown pre-worn one and used it for the first time the other day and was really impressed. As it is much bigger it smoothed all the lines out a lot quicker and with much less effort.
all old trowels that worn seem to bend that way any way
it doesn't make any difference then?Permashape might trowel flat once the gear's stiffened but they don't put it on flat. Haggis is right.
nope yr wrong, its easy to get the wall virtually perfectly flat on second coat with a perma, i put on with a 5yr old perma and trowel up with an 11yr old.
