Have you contacted the tradesman? ? I bloody hope you have ?? What did he dab on to? Brick? Block ? Painted? Etc would help with a bit more info ??Hi,
just had some plastering work done and the dot and dabs have come away from the wall!!!
just asking the question his there anything I could do to re - connect it to the wall instead of taking it all down ? has its still all in place but just bouncing when you push it.
Is he reluctant to rectify the job?Thanks lads.
He dabed onto brickwork and he coverd the full wall in pva
Why pva brickwork??? Im sorry mate but this is the work of a numpty am afraid so tell the good folk on here where you are based ?? And swift assistance will ensueThanks lads.
Whats wrong with pvaing brickwork? Bit harsh to jump straight down the spreads throat. If im dabbing the same day or next day ill just wet it down but if its being left ill give it a weak pva so the walls aren't dusty. Nothing wrong with it.Why pva brickwork??? Im sorry mate but this is the work of a numpty am afraid so tell the good folk on here where you are based ?? And swift assistance will ensue
same as just for the dustWhats wrong with pvaing brickwork? Bit harsh to jump straight down the spreads throat. If im dabbing the same day or next day ill just wet it down but if its being left ill give it a weak pva so the walls aren't dusty. Nothing wrong with it.
Sent from my GT-I9195 using Tapatalk
f**k off hows that !!??Whats wrong with pvaing brickwork? Bit harsh to jump straight down the spreads throat. If im dabbing the same day or next day ill just wet it down but if its being left ill give it a weak pva so the walls aren't dusty. Nothing wrong with it.
Pva before dabbing brickwork !! Need your f**k**g heads testing !!!!
Thanks lads.
Horray sense at last !!!I have never pva before dabbing but always brush the walls down and I have damped them down as well
Yet you dont give a reason it shouldn't be done...
As i said mate if im dabbing same day or next day then ill just wet it but like if it's being left for any reason ill weak pva just to stop s**t getting everywhere.
I aim to please
