dry lining corner tape
devneydutch
How do you mean?
When dry lining the but joints are jointed with a fibre tape that can be sanded back.
The corner angle tape (painters are using) is just card/paper so if there isn't enough filler over them the paper pulls through when sanding.
wondered if there is a fibre angle tape
ChrispyUK
why would that make any difference?
Lastlaff
You’re sanding too hard then - or put more gear on the tapes. There isn’t fiber corner tape.
TonyM
I do the airless plaster. I use Fibafuse for internals £8 a roll from Belmore. It will sand smooth, but you should still cover it well with the gear. It’s very fine fibreglass mesh. It won’t fail like paper tape as the material goes through it.
devneydutch
Do you ever use square edge board and scrum tape on the joints? I'm doing a small room this way with another coat of spray plaster on top.
At the moment we are using tapered edge board and dry lining before we spray.
TonyM
Yes, but put a tight coat of filler over the scrim
