S a plastering
What the best drywall bit for impact driver mine is a bit powerful knocking the screws under the paper doin me nut in
f**k the impact driver off is the best thing to do. Only a noisy, stupid chippy uses one of them for boarding.What the best drywall bit for impact driver mine is a bit powerful knocking the screws under the paper doin me nut in
I know think i might its s**t for plasteringf**k the impact driver off is the best thing to do. Only a noisy, stupid chippy uses one of them for boarding.
Too powerfulI know think i might its s**t for plastering
Where you get it from mate have u a link palI use to use an impact driver aswell doesn't matter what bit you use mate the f**k**s are to powerful I used the makita gold torsion magnetic bit holder it holds the screw in place i only bought it as was sick off splinters off the screws but this reduced banging the screws through the paper as it has a sleeve over the drill bit so there's abit of a guide on how far to screw them up before you go overkill and put through the paper
Just take your finger off the trigger before it goes through, have a bit of finess about your work Iv never heard such b*ll***sWhat the best drywall bit for impact driver mine is a bit powerful knocking the screws under the paper doin me nut in
Haha tried that if you dont catch it right goes through its the dewalt known for being powerfullJust take your finger off the trigger before it goes through, have a bit of finess about your work Iv never heard such b*ll***s
Found it mate do they take the Normal small ph2 bitsI use to use an impact driver aswell doesn't matter what bit you use mate the f**k**s are to powerful I used the makita gold torsion magnetic bit holder it holds the screw in place i only bought it as was sick off splinters off the screws but this reduced banging the screws through the paper as it has a sleeve over the drill bit so there's abit of a guide on how far to screw them up before you go overkill and put through the paper
Does it not have the switch near the battery?Haha tried that if you dont catch it right goes through its the dewalt known for being powerfull
Yes its 3 speed the new type number 1 speed is s**t an 3 way too fast i have it on 2 but still powerful its only now an again it pushes through but still annoyingDoes it not have the switch near the battery?
Iv used a makita impact driver over 12 years never had an issue
Might be something with new brushless being too efficientYes its 3 speed the new type number 1 speed is s**t an 3 way too fast i have it on 2 but still powerful its only now an again it pushes through but still annoying
Get yourself one of these mate.Yes its 3 speed the new type number 1 speed is s**t an 3 way too fast i have it on 2 but still powerful its only now an again it pushes through but still annoying
There great and Iv got 1 but there not suitable for every situationJust buy a proper drywall gun. Use the correct tool for the job.
Got one pal but need it for reboarding so can feel the tension going in
Ive got one pal its just reboarding ceilings you cant always tell if they have gone in with the collatedJust buy a proper drywall gun. Use the correct tool for the job.
ThanksCheap option![]()
Sound mate what they actually called when i search emThese are about 3p each
Drywall dimplerSound mate what they actually called when i search em
CheersDrywall dimpler
Yes mate they take any bit,its like the drywall dimpler tony just posted when you put the magnetic sleeve on,you can still pierce the paper with it if your not careful but i found it quite useful as a rough guide when to ease up on the powerFound it mate do they take the Normal small ph2 bits
Ringmagnet @smoother09I tried one of these designed for drywall and found it naff. Reviews are good and I treated myself at £13![]()
Wera Ringmagnet. Anyone like it?
Better with a long bar as I said in above post imo
Good one! That’s actually quite decent for you.Ringmagnet @smoother09
Watching with interest!Ringmagnet @smoother09
Yeah noisemaking twonksf**k the impact driver off is the best thing to do. Only a noisy, stupid chippy uses one of them for boarding.
I don't use the black screws because of the splinters I use the zinc plated silver onesI use to use an impact driver aswell doesn't matter what bit you use mate the f**k**s are to powerful I used the makita gold torsion magnetic bit holder it holds the screw in place i only bought it as was sick off splinters off the screws but this reduced banging the screws through the paper as it has a sleeve over the drill bit so there's abit of a guide on how far to screw them up before you go overkill and put through the paper
