Pagey
No problemOk - Thanks very much for the advice!
Sorry to say but from what I’ve just read, He definitely IS NOT a plasterer! Asking you to fill his mistakes and talking about sanding down his work!!! What a complete embarrassment!!!Hello,
I'm up against a bit of a deadline to get a room finished and painted.
My plasterer is telling me he will finish the plastering tonight, I should then fill any bits that aren't smooth and do a mist coat in the morning then he will come back and sand the bits I've filled tomorrow afternoon. then I can continue pianting this weekend.
Can I fill over new plaster? If so what should I use easyfill or caulk?
Also I have paint for new plaster which I understand is what I need to allow the walls to breathe, but will that be OK to use even if the plaster is still pink? Finally if the paint is OK, should I water it down - it doesn't say that on the tin, but I'm not clear for the first coat.
Many thanks
Gotta feel for some people and how he can call himself a Plasterer I will never knowSorry to say but from what I’ve just read, He definitely IS NOT a plasterer! Asking you to fill his mistakes and talking about sanding down his work!!! What a complete embarrassment!!!
Easy , " I'm a plasterer "Gotta feel for some people and how he can call himself a Plasterer I will never know
It’s was I’m semi retired nowEasy , " I'm a plasterer "
Sorry just realised I'm also not clear - should he sand down any other rough bits (not the stuff that he has already filled but where there are rough bits in the plaster ) before or after the mist coat? Thanks againNo problem
I read that wrong thought was aimed at me was premature againEasy , " I'm a plasterer "
Do feel bad for chiefy but the best bit was when he said because the blokes on checkatrade he IS a plasterer??Gotta feel for some people and how he can call himself a Plasterer I will never know
Paint it first after what I said and see what you got put some pics upSorry just realised I'm also not clear - should he sand down any other rough bits (not the stuff that he has already filled but where there are rough bits in the plaster ) before or after the mist coat? Thanks again
I thought these things were fool proof and they been checked outDo feel bad for chiefy but the best bit was when he said because the blokes on checkatrade he IS a plasterer??![]()
They check the paymentsI thought these things were fool proof and they been checked out
Just get the ruff c**t to rub it all down before and after! just for taking the f**k**g piss mate!!Sorry just realised I'm also not clear - should he sand down any other rough bits (not the stuff that he has already filled but where there are rough bits in the plaster ) before or after the mist coat? Thanks again
And your expected to compete with this what chance is there glad I ain’t on itThey check the payments
Thanks!Paint it first after what I said and see what you got put some pics up
Next time come on here looking for a Plasterer and go for a member who been around a while many can vouch for them might be a bit dearer but at least won’t have problem your having now worth the extraThanks!
I second thatCan we have some pictures of his plastering please and your bum x
You will get away with your mist coat, but to use filler and sand when its really still wet is not a good idea, you'll just give yourself more grief and work, just out of interest have you paid this clown the full asking price or kept a retention to pay towards a decent spread, for the re-skimHello,
Many thanks
You will get away with your mist coat, but to use filler and sand when its really still wet is not a good idea, you'll just give yourself more grief and work, just out of interest have you paid this clown the full asking price or kept a retention to pay towards a decent spread, for the re-skim![]()
I wouldn’tHa, unfortunately I paid him half upfront... So do you think I will be OK with the mist coat now, even though much of it is still dark brown? He only finished the skimming last night
waite until its dry before you do any thing under normal circumstances you could crack on with your mist coat, but you don't want to have to take any blame IE going on to it too early, open the windows stick a fan in the room and get it dry firstHa, unfortunately I paid him half upfront... So do you think I will be OK with the mist coat now, even though much of it is still dark brown? He only finished the skimming last night
bloody brass neck mate so it isOn jobs like a room I wouldn’t ask for doe up front
To be quite frank, it doesn't take much extra time to have a job finished to a paintable finish as apose to leaving rough... hard to comment when your not seeing the job but you really shouldn't be filling areas after it's been plastered unless you might have potential cracks though movement ECT as a final resort... regardless of circumstances, your not gonna know how bad it is till you've finished painting it... get the job done right... no excuses then.. but that's just my opinion mate..Hello,
Many thanks
Wait tillHa, unfortunately I paid him half upfront... So do you think I will be OK with the mist coat now, even though much of it is still dark brown? He only finished the skimming last night
You're quite good at Easifil baronWait till
It’s completely dry , mist coat , then fill as required
The bestYou're quite good at Easifil baron
I’m pretty good at rubbing downThe best
I taught you wellI’m pretty good at rubbing down
Uses to work with a fella and as soon as walls were set he was out with the fillers, sadly that's a true storyShould t be doing any filling over new Work
