MikeAtthis
Is it down to the lake fear lolNice to hear your enjoying work josh.
I'm bored of spraying now, where do I go from here?
What are tight mesh Goggles?Trouble with goggles etc they steam up. Those tight mesh goggles are good i think jainsawusers use them wen there using the things they use
what chainsaw users where when using the things they use..............like chainsaw's etcWhat are tight mesh Goggles?
I wear safety specs all the time when pottering about in the garage... since laser eye surgery I feel naked when using power toolswhat chainsaw users where when using the things they use..............like chainsaw's etc
Is this dudes machine a ritmo or g4 ?
It's a pft monojetI think it's too small for a g4 but I ain't no machine man
ThanksPft monojet
Are they a bit more powerful than ritmo but less than g4 ?
Same as a g4 and a lot lot faster than the ritmoThanks
Thanks that's why I asked it seems to throw it out alot fasterSame as a g4 and a lot lot faster than the ritmo
There's a brand new ritmo up for sale on fb, someone bought it never used it now up for grabs you might get a cracking deal on itThanks
he's holding out for BG to make one so he can trial it and be come BG Machine Poster BoyVince you need to hurry up and get a machine, your losing out flirting with which one to get.
Speak to your local PFT dealer lad.
it's a very clean machine it's not been usedThere's a brand new ritmo up for sale on fb, someone bought it never used it now up for grabs you might get a cracking deal on it
Same as a G4 mate both 3phase 5.5motorsThanks
Was just reading about that monojet. Says it will spray aggregate up to 7mm.
Is there not a machine that will spray pre mixed sand & cement without going into the diesels??
Surely the monojet would? (Reading the specs at least)
Retire.Nice to hear your enjoying work josh.
I think Bobby or someone has done it with a ritmo?
It has to be pre mixed. As said before if the material can separate from the water then it won't travel consistently down a pipe at pressure. Leave whatever you're planning to use in a bucket and see if the water rises to the top of the mix. If it does it won't spray. It has to be thixotropic.Bobby uses ocr.
I'm on about s&c pre mixed in mixer
Yes I've done it a few years backI think Bobby or someone has done it with a ritmo?
Did you use a certain sand mateYes I've done it a few years back
It does need to be a decent,fairly fine sand with plenty of lime
My mix was 4/1/1 with plenty of feb mix
It's needs to be mixed so it's creamy and the consistency needs to be the same really
I did 120m2 of party walls with it at 8mm
Apology accepted [emoji23][emoji23][emoji23][emoji23]Bobby uses ocr.
