puddove
I can buy one bead of any colour if i want ,just shop around ,i got court out with all that full box s**t back in the day
you sound like a yorkshire man buying 1 bead at a time
It's just easier and less strain on the body I thought Ian.
I'll try it a little wetter next time.
The first panel seemed a little to wet to do in one pass so we went a bit stiffer but that one did feel a little more stiffer on the ruling off.
more getting a point across ,lol....and how very dare you !you sound like a yorkshire man buying 1 bead at a time![]()
If u don't mind me asking how much will one of them set me back ?Had our very first spray with our ritmo today.
Picked it up and has training last Friday.
We were spraying EHI one pass (ish) over matie.
Had a hiccup at start where we weren't giving enough time for mix to come through after adjusting water and almost caused a blockeage.
Luckily Ian from @PFTwales was on the phone and helped us through quickly enough.
We Sprayed 60m2 including set up, the hiccup and clean down in about 4.5hours.
Videos aren't the best but we were more worried about nothing going wrong first time.
Any constructive criticism would be appreciated, if you just want a pick fault for the sake of it without helping then f**k off.
Advice appreciated.
Spraying again early next week.
Then got about 10 jobs booked for April onwards.
We only use Parex and have the ritmo L if this helps.
Link RemovedLink Removed
@UKPlasteringmachines will help you out with thatIf u don't mind me asking how much will one of them set me back ?
or pft wales@UKPlasteringmachines will help you out with that
just an arm and maybe a legA little machine on finance ..
What do you do, put a kidney down as a deposit.
5400 plus vat for a full set up if you're not so far from wales
YesIs that for the 'L'?
You want to try a 3 phase or a diesel now you've got a taste for it mate there twice as quick as the ritmos
I've gone from the 24 to a m330 and need a slower rotar and stator tbh 22 l/min is quick man.You want to try a 3 phase or a diesel now you've got a taste for it mate there twice as quick as the ritmos
pretty much what i paid for mine off les5400 plus vat for a full set up if you're not so far from wales
you need one to slow it down to the ritmo speed lolI've gone from the 24 to a m330 and need a slower rotar and stator tbh 22 l/min is quick man.
Sounds like its the wrong machine for your needs then.I've gone from the 24 to a m330 and need a slower rotar and stator tbh 22 l/min is quick man.
Good talking salesman lolSounds like its the wrong machine for your needs then.
The eze 24 seemed fast at first we will get used to it, and at least we have the power when we need it.Sounds like its the wrong machine for your needs then.
can you not change the r/s on them
Will it be a copy of the ritmo L but blue?We are potentially bringing out another R/S for the EZE 24 but it wont be much faster to be honest.
We are focusing on our new machine at the moment though
Will it be a copy of the ritmo L but blue?![]()
What type of work do you do then, I thought you were mainly domestic.The eze 24 seemed fast at first we will get used to it, and at least we have the power when we need it.
