It should be. People are doing beams with it!Least it’s keyed well
It is mateFuckinell...please tell me that isn't bonding??
Typical domestic job,some skim shiner having a go at externals lolStarted small little job to tidy up and make good exterior first job smash off thistle bonding scratch the builders left.
I ain’t the best renderer I’ll admit but what the hell going on out there
View attachment 27701View attachment 27702
f**k**g nightmare to get rid offStarted small little job to tidy up and make good exterior first job smash off thistle bonding scratch the builders left.
Ahh that killed me!!
Boards dabbed with skim is another one!Hacked off old render and seen beads bedded on with bonding loads of times! Lol.
I can’t help it but It does put a rye smile on my face when I come across some of the s**t that’s been hidden.Boards dabbed with skim is another one!
Yes and then you get the satisfaction of looking flabbergasted while shaking your head.. sucking your teeth and saying “ooo done that?!”I can’t help it but It does put a rye smile on my face when I come across some of the s**t that’s been hidden.
Bonding is interior backing plaster. It will suck up water, no good for exterior at all.Why is it wrong? (so I can understand)
Skim dabs won’t hold s**t on the walls
(Weren’t sure which one you were asking about)
Tbf boards were dabbed with (pink ) or skim plaster before dri wall adhesive came out , before my time but if I’m correct up until somewhere in 1990sahhh ok! I thought that looked like bonding (also didn't know what bonding was - thankyou for the definition!)
You know it haha!Yes and then you get the satisfaction of looking flabbergasted while shaking your head.. sucking your teeth and saying “ooo done that?!”
Common thing years ago even on big sites, Board Finish or Bonding.Boards dabbed with skim is another one!
And then you suddenly realise that you did it five years earlier.Yes and then you get the satisfaction of looking flabbergasted while shaking your head.. sucking your teeth and saying “ooo done that?!”
Cannot remember the name of it but B G did do an adhesive in the 80's that resembled bonding in texture cos I was using it to Dab insulated boards somewhere in Leeds in 88.Tbf boards were dabbed with (pink ) or skim plaster before dri wall adhesive came out , before my time but if I’m correct up until somewhere in 1990s
Mental, I knew they used to dab with bonding but sanctioning skim?!Common thing years ago even on big sites, Board Finish or Bonding.
What do you think they used before bonding compound ...Boards dabbed with skim is another one!
NO Vincey .Bonding compound was well in use by the 80's when i started but it was all BG stuff and was gray horrible s**t .Tbf boards were dabbed with (pink ) or skim plaster before dri wall adhesive came out , before my time but if I’m correct up until somewhere in 1990s
But but but.... skim?! Can’t get my head round that oneWhat do you think they used before bonding compound ...
.The concept of sticking boards was thought of before the production of an adhesive was ,But but but.... skim?! Can’t get my head round that one
Last year I ripped off a load of boards at a house built in 90s all the boards were applied with skim on blocks tbh I never knew it was the case back then to do that but tbf it lasted 25 odd yearsNO Vincey .Bonding compound was well in use by the 80's when i started but it was all BG stuff and was gray horrible s**t .
How do you know it was skim and not bonding compound .? just because it was pink ? AL the gypsum mined in the south is pink but any from the north is grey. Many years ago (1990's) i did some work in Liverpool and the finish was grey . Well it used to be ...Last year I ripped off a load of boards at a house built in 90s all the boards were applied with skim on blocks tbh I never knew it was the case back then to do that but tbf it lasted 25 odd years
