D
Deleted member 40920
Guest
Makes one of us. Still no idea what he's on aboutgot it now, makes sense.
Oh I get it now.Makes one of us. Still no idea what he's on about
AyeOh I get it now.
Link Removed
whats a speedskim?No just get it on as fast as you can. One over whith speed skim happy days
When you skim really fast?whats a speedskim?
I’m reading this pissed so basically I’ve read it and still pissed goodnight
I run over the 1st coat with a spat and usually mix fresh stuff for the 2nd coat .
I see RWF on youtube mixes 3 bags in a tub and uses the same tub for first and second coat , is the stuff not gone too stiff to spread by the time it comes around to the 2nd coat ? Maybe I'm slow ......
Why don't you try and let us know? Will be interesting to see what happens!I run over the 1st coat with a spat and usually mix fresh stuff for the 2nd coat .
For that to work you have to be quick. You have to mix it thin. And the first coat has to be very tight
I might give it a go , I burnt a hole in my tub so I must order something that will hold a 3 bagger . No matter what happens sure a nap sponge will make a job of it anyhowWhy don't you try and let us know? Will be interesting to see what happens!
Also depends on my mood. I’ll either break a room into 2 gauges of the same mix for each. Or 1 big gauge with 2 mixes
say again?If I want to crack in I first coat stuff then second coat with fresh gear but the also first coat more of the room then second coat the first coat the rest... like a rolling set.
It's hard work but it works to push jobs along...
I 99% of the time use a fresh mix for the 2nd coat and well
say again?
Expanding foam is a nightmare . The slabbers I work after decided to squirt it in every joint lately that they don't cut right , horrible horrible stuffI always flatten mainly due to absolute shite skim over , f**k me today there was diabolical board work,expanding foam and patch bits of bone dry hardwall, got to the point on domestic now where even I had enough of skimming as every c**t thinks they can prepare a room
Hopefully I’ll survive the year outside
Around here the Building Control guys request fire rated foam be used to fill the board gaps in partition walls, even double boarded ones.
For Tapit - just copy RFW speedskimming
easy huh? And eat the biscuits before the dogs do
RWF sponge floats so maybe he just coats straight on top of first coat? I normally flatten between coats and mix fresh. I used to second coat straight over and flatten first coat as I was moving along. A guy I worked with years ago put his first coat on so neat it looked like it had been flattened already, i never mastered that technique though.I run over the 1st coat with a spat and usually mix fresh stuff for the 2nd coat .
