ggb plasterers
Advice please have a large hardwall and set job coming up, whenever I've done the odd wall I've ruled off then put a devil scratch over, I this the best option or any other methods? Cheers
I rule off with speedskim gets it flatter and closes it in nice
I always use a feather edge mate, where can you get these diamond floatsUse a straight edge for ruling mate it may look flat with a speed skim but if you put a edge on the wall once gone off you know the difference between the two, I use a plastic diamond float for floating hardwall there nice to use try one.
Refina mateI always use a feather edge mate, where can you get these diamond floats
Do you use a machine though, I should of stated that.I've no bother working on my own with hardwall, enjoy it.
Float until 11 and then two small gauges.
I guarantee if those three men worked separately, they would have a lot more work done.
Old school.
Float up, feather edge and devils in the morning.
Skim up in the afternoon.
Real plasterers job. Love it.
Rule it off then devil scratch and some times a waffle when it's nearly just incase there any high spots prefer sand cement and skim tbh
Welcome backBeen around mate... just not on here for a while...
I cant stand floating any more.....units your doing always seem damp.
The smells horrible ...the dust...the setting up (beads bags water etc).
Cleaning up twice in 1 day.
Soaking walls on thermo walls.
Concrete walls not setting.
Urgghhh. Dont miss them days.
