Most of the time I use spirit level . Once you laid on mark the wall with the spirit level same distance as you will with screeds and rule off. Job done.
Hence I don’t use screeds so oftenwall should be level in the first place. plaster is only a panel to receive decoration.
at the end of the day whatever way u choose .if it looks right then it is rightHence I don’t use screeds so often. There’s always areas here and there, but not something I can’t manage without screeds.
Amen normat the end of the day whatever way u choose .if it looks right then it is right
god bless my sonAmen norm
To be fair was only taught to plumb up kitchens and bathrooms, living rooms bedrooms etc get just straight with rule, unless the walls miles out!
Spot onat the end of the day whatever way u choose .if it looks right then it is right
My sentiments exactly Stormin, no point getting walls level when window frames and door liners aren’t, it just makes your walls look pissedat the end of the day whatever way u choose .if it looks right then it is right
True that!Let's not kid ourselves.......decent blockwork is a doddle.
I've followed some proper shite brickies .
the tolerance is unbelievable.
Not seen a bricky in the last 10 years do one plumb... I have floated out some hopeless walls in the past
