Chris W
noooo you berk! i said, i'd use bonding... i 'would' use bonding... for this job...lucius said:Never done it but i thought you fixed battens the required distance from the corner and then made a template to the required radius notched out to run up the battens. Chriss did you realy say you used bonding in a swimming pool.
Lucius
swimming pool i used rapid hardner in render to base the corners out then used the lip of a builders bucket to form the curve..
just happened to be exactly the same radius as the clippy edge bead they had round the top 8) couple of screeds, one either side and ran off them...
think del and co with the coving etc is a nice idea but it'll depends on how flat the wall needs to be... gonna be looking at 10mm of skim or a coat of bonding all over first to get it level to the edge... bit of work...
could always stanley the sides of the coving and hack out the existing plaster a bit to bury it in i suppose?
dinner plates come in all sorts of radii.. theres another idea, rounded edges and angled too....even get plastic ones
