I'm convinced more likely to get a crack the bigger the gap.
But the above advice is correct.
Personally I aim for tight a fit as possible
I remember that green stuff and the brown hessian around the edges.It would take ages to get a couple of ceilings ready.When I was a kid in Ireland helping my dad I'm sure they left a gap between boards. They used a scrim similar to today's but it was green and not sticky.
I'm sure on 4'x2' slabs you didn't need to scrim either , just leave a gap for key.
we did use to leave a 2mm gap between the boards if it was in the spec.
the 4' x 1.5' lathe sheets had a rounded edge, did not scrim the joints but filled the gaps then skimmed the ceilings.
lathe boards on ceilings, 8' x 4' where called wall boards.
The last house I can remember doing with lathe boards was back in the late eighties.we did use to leave a 2mm gap between the boards if it was in the spec.
My father a farmer thought it was madness putting 8x4 on a ceilingThe last house I can remember doing with lathe boards was back in the late eighties.
Sooo many cracks.
I ALWAYS leave 3/5 Mm gap, I’m convinced it helps it not to crack, I also do something else but not giving my secret away to you load of bodgers
Where did he put themMy father a farmer thought it was madness putting 8x4 on a ceiling
No where ,he was a farmer ,Where did he put them
A lot of tackers used to use a nail as spacers. And it really did happen.So how are you meant to keep an even 2-3mm gap when boarding ceilings? Fix some sort of Packer to space the boards apart? Never going to happen for me, I just butt them up tight .
I trained that way in 85A lot of tackers used to use a nail as spacers. And it really did happen.
I was kicking my spotty ball about in 85 lolI trained that way in 85
I know itI ALWAYS leave 3/5 Mm gap, I’m convinced it helps it not to crack, I also do something else but not giving my secret away to you load of bodgers
Two hr break ?I know it
That ain’t even a secret it’s a mustTwo hr break ?
Tack a nail in, simple and quick I guessA lot of tackers used to use a nail as spacers. And it really did happen.
Maybe on domestic but can’t see that happening on big sitesTack a nail in, simple and quick I guess
Even on site work a gap was insisted on.Maybe on domestic but can’t see that happening on big sites
Still be 3mm..........Put your cock in the gap
I'd already bought my first house by then, God I feel old. Thanks.I was kicking my spotty ball about in 85 lol
Old school blokes I know will insist on it but on site it’s a case of throw them up I was under the impression that the gap was needed for when you old boys had to go round and hessian the joints, plus if bg spec paper tape would the gap be needed,me personally can see both arguments for itEven on site work a gap was insisted on.
