How did you find the ritmo spraying hardwall? I put on a chunk of hardwall with the ritmo on wednesday then set in the afternoon. I haven't sprayed much of it, but find it a bit spluttery and I'm always worried about it setting in the pipe when I put the gun down to rule.
It was my first time, so I'm green m8, but it went good, I didn't really enjoy skimming it though! Was pulling in quite quickly! Might give it a little mist with the roller before skimming next time!How did you find the ritmo spraying hardwall? I put on a chunk of hardwall with the ritmo on wednesday then set in the afternoon. I haven't sprayed much of it, but find it a bit spluttery and I'm always worried about it setting in the pipe when I put the gun down to rule.
I've been saving it for you! Are you doing the mine next Friday?Reckon if you got that 120mm butt plug wez you'd have moved a bit quicker
Had a 12mm cap on as you have mentioned before, and soon learned to pull the air back to neaten it up. But yeah farting out the gun is what I meant by spluttery, I just find theres a little more mess when its spluttering. Maybe i'll lower the water next time.Wez hardwall sprays better with a bigger/worn spray cap.
Its also better if you pull the airtube back a bit more than how you have it for render, you want it to sound a bit farty when its spraying
did u have problems before with hardwallHardwall sprays sweet. No spluttering or nothing
Are u putting the hardwall on in the morning m8 multi in the afternoon can u get a lot more metres on with the spraying
I haven't done much hardwall + set before m8 so it's difficult to gauge, but we sprayed on about 40 odd metres & skimmed it the same day so quids in really, there were 3 different backgrounds that we went over so hardwall was ideal!
im using a14mm which ive opened up a littleWez hardwall sprays better with a bigger/worn spray cap.
must br the substrate pal coz ive sprayed tons of hardwall n currently on 30,000 m2 job amd it hangs like mad when u skim it managing skim 80 m in one hot with no suctiom (2n1 gang)
What machine is that?im using a14mm which ive opened up a little
Gyp-prime on lightweights before the hardwall and the suction is no bother.I hate having to turn back and set it the same day and the associated suction issues
concrete blocks wigan?
