CTPlastering
Am local , obv mates rates for it ;-)
Could be a number of things mate.did you adjust speed as machine was spraying?Ani ideas on why it would spray then come out like you were squeezing toothpaste then spray etc etc?
That's what did my head in. I got the gear close before putting the pipe on then fir some reason it's just started spraying water. Reduced the water then it's sprayed, went toothpaste, sprayed, went toothpaste. Only made small adjustments like Les told us. The pressure on the gauge was going 2 high then too low. Ran out of gear so I just cried and let the boy tidy up.....lolBear in mind when you are spraying it will take 15 -20seconds for the change to get noticed at the gun. So get the gear as close as possible at without the pipe on, connect pipe if you make any adjustments mid spray they should be small.
AyeCould be a number of things mate.did you adjust speed as machine was spraying?
1st go at spraying rendaid and it was a fewkin disaster. Got the test gear sorted. Attached the sprat pipe and started spraying just water. Rang Les got sorted then it started spraying and stopping. Messed about with the water and speed, ran out of gear in the end.....f**k**g machine.....lol
Anyone wanna buy a Ritmo ;-)
That probably didn't help mate.that would fook up the consistency of the gear.
Les said i could increase the speed rather than messing about with water to increase the pressure on the guage ??. He also said spraying rendaid should have the consistency of skimming " Its a completely different animal is T'rendaid".............exact quote..........Remember if you increase the speed, you need more water to keep up with the increased volume of powder. Think of the flow bottle reading as your water input and the speed dial as your powder input.
Les knows the game and machines better then most to be honest , I found he was always at the end of the phone if help was needed , but he is very rarely on here these daysLes said i could increase the speed rather than messing about with water to increase the pressure on the guage ??. He also said spraying rendaid should have the consistency of skimming " Its a completely different animal is T'rendaid".............exact quote..........
does the cap size matter Mike ?you do need the gear wetter . when you make adjustments to the speed and water it will spray a couple of meters before you see the differences and i think how you have the air pipe makes it look wetter but that could be me lol
cheers marra...................your a true diamond.....................Mike has the same machine as you Arti , that's why I tag him , and he is a mate
