Course is what I was thinking but the screwfix ones are only 60mmI’d go for the coarse thread ones.
Serious business choosing screws.Sorry but I was actually trying to be sarcastic and funny - trying to fit in.![]()
No way .. I missed thatSorry but I was actually trying to be sarcastic and funny - trying to fit in.![]()
Full threaded shank - gold screw from screwfix would be my choice
I'm chameleon.I knew you were black country
It's for overboard.Why not plasterer board screws
More expensive for one. especially at 5x125mm. Might even add that I would use star /torx head ones.Why not plasterer board screws
What you selling?Sorry but I was actually trying to be sarcastic and funny - trying to fit in.![]()
I'm chameleon.
[/QUOTE
f****** lizard
Don't forget washersMore expensive for one. especially at 5x125mm. Might even add that I would use star /torx head ones.
No I would do without otherwise the screw head would not self countersinkDon't forget washers
a coat of artex would hide that.No I would do without otherwise the screw head would not self countersink
You can get me washers that are recessed,No I would do without otherwise the screw head would not self countersink
I never thought of that.You can get me washers that are recessed,
But I wouldn't worry too much I would dip the ends of the screws in some wood glue to ensure they have sufficient grip into joist
Exactly you have just got to screw that bit harderI never thought of that.
Belt and braces.
Presumably if you tighten the screws up good, they'll press the washer into the board enough that they'll be flush?
Make sure you use galvanised washersExactly you have just got to screw that bit harder
Now's your chance if you're sell a roll of your tapea coat of artex would hide that.
What do you think we use for double boarding then you plank?It's for overboard.
Pb screws won't bite.
@bilge I'd happily use 50mm coarse thread plasterboard screws for overboarding an Artexed plasterboard ceiling. Minimum of seven screws across the width of an 8x4 board, eight screws at the ends.
Not sure what you mean there. Impact adhesive - as in Evo-stic. The ceiling has an artex texture and so there will not be much contact. Would a no nails type adheasive be better.Nowhere near enough for overboard that.
OP - you should also consider impact adhesive at the points where you plan to scree/along the joists. Just bang it on where you've marked them and youll be grand.
noIs that what everyone else does then when over boarding - add a glue to every edge of the board
Do I need to start a new thread for that one . Because I am still looking for peoples favourite BP screws or ones they have brought and not got on with like here
Just want to clarify something, it was a question about screws for cross battening. I said use wood screws because I thought the question was asking what screws to attach the cross batons to the rafters through the old PB. Reading some replies it looks like people thought I was saying to use wood screws to fix the over-board to the battons - hence washers-artex over them and so on.
You need to knock all the peaks off the artex and pva the ceiling so as to get a good bond for the glue.Not sure what you mean there. Impact adhesive - as in Evo-stic. The ceiling has an artex texture and so there will not be much contact. Would a no nails type adheasive be better.
Is that what everyone else does then when over boarding - add a glue to every edge of the boards.
What about a papered ceiling - the glue is wont help much there will it ?
Yes plasterboard adhesive will do, watch for screw heads popping on new plaster most screws a very light oiling so it's sometimes necessary to give the screws a slight squirtle with degreaser, and then apply PVA to heads of screws with small artist brushI think I am ok with the artex as I was the person who put it up around 20 years ago, I have already planned to knock off any peaks but if the artex did have asbestos in it I would not be touching it at all.
Don't fancy using contact adhesive because that is only one touch and I may need to slide the board in place slightly.
And depending on the paper type when you scrape back where you want to glue you are creating a slightly lower section and the adhesive will not make proper contact - hence my thoughts on using a no nails filling adhesive or how about PB adhesive.
I could chuck the screws a handful at a time into a container of alcohol and give it a shake.Yes plasterboard adhesive will do, watch for screw heads popping on new plaster most screws a very light oiling so it's sometimes necessary to give the screws a slight squirtle with degreaser, and then apply PVA to heads of screws with small artist brush
Same with plasterboard. The issue isn't the boards falling down, it's screw heads popping and leaving unsightly craters in the work.@Groove37 when a chipboard floor is screwed to a new build joist the best practice is to glue the chipboard sheets to the joists as well as each other with a D4 glue
Thanks for that personally I’ve never glued or no anyone who has glued a simple ceiling overboard find joists chalk line through cut boards to suit 50mm dry wall screws up into joist never had a problem@Groove37 when a chipboard floor is screwed to a new build joist the best practice is to glue the chipboard sheets to the joists as well as each other with a D4 glue
