johniosaif
does not help with damp though worst thing for damp is bonding,Nowt wrong with a handful of bonding in the render if your in a rush.
I used to work for a damp coursing firm years ago doing council houses, so we had to be in and out as they were usually occupied and as result were told to float up then skim the next day and i can tell you we had no end of problems with cracks etc .BUT i was young and easily led in those days and now i would never skim the next day but would leave it as long as possible (3-5 days). over the years have been to many jobs where the skim on a wall has been hollow and found it shelled off clean once you get behind it but the render has been fine, but this can also be because there was not enough key when rubbed up.
I have seen it done by damp firms, even seen them putting in bonding in the render to speeed it up, damp proofers are the cowboys of our game generally speaking ie those that only do a metre high all their lives..
I find rapid cement seems to have problems with salts...Better to put rapid cement in to speed things up....That way you can skim the same day..........:RpS_wink:
i would say the majority of render /skim failures i have see, have been down to lack of mechanical/key due to poor rubbing -up , also the incorrect skim plaster for S&C backings ........
multi is correct nowadays for skimming over render, board is just for board, carlite for skimming only carlite products, used to be siraphite b for render but muti replaced this and as its name suggests.....What is the correct skim plaster???? Whats wrong with plane old Board finish?????
Is cement based undercoats s/c render if so I stand corrected..Errrm.......seems board is for waterproofed cement base undercoats.........
See here
Link Removed
See here
Link Removed
Malc it be old school, but imho its still the best way, and a builder i do bits for only floats with sand and cement, and it always comes out mint, if left to cure properly.
Sand/cement suits refurb work, especially old wrecked and damp properties, light weight plasters are very expensive still compared to sand and cementi think that sand and cement floating is obsolete. when i see the key on modern blocks ie celcon, celcon solar blocks, i have seen sand and cement sheet off these blocks.
there was a time a few years back that some plasterers did not devil float but just floated smooth as they thought that multi finish had improved adhesion, so why did you need a load of scratch lines slowing you finishing down. i have seen the set on these walls breaking key.
if ever a builder asked me use sand and cement floating i always ask is he supplying a fork lift to get the material up above ground floor? he then realize that bagged plaster will be cheaper then to hire a fork lift and driver
You can't skim sand n cement the same day as the surface will not be firm enough to take it as the grains of sand come away (if that makes sence) and the skim just falls off ,its a disaster to even try it.
Plasterboard dosent have a key.
I disagree strongly on this Bubbles. never had it debonding in 25yrs of plastering, more likely debonds due to dust if left too long..
What happens if you let it dry completely, say a month, then skim it, and sucks like fcuk ?
If you're working onto low suction blocks then IMO it is even more important to make sure that the S&C has cured but you'll get a lot more suction that when working on high suction blocks.
Can you explain why that is?
No I meant, how does he explain why he gets more suction when skimming render on low suction backgrounds, than Celcons.
i was taught that you get oppoisite suctions , low suction on floating =high suction on set. high suction on floating = low suction on set.
