IWI on 9" solid wall
Any links?
If you type in isover into YouTube it should be on there somewhere. I had a quick search and couldn't find the exact one but found the isover fibreglass iwi system. It's the exact same method only the insulation is damp proof or moisture resistant. It's designed for damp houses and cottages. Gift to put up.
Exact same method as what?
You screw on them metal battens to the wall, stick the spike clips in then push the insulation into spikes then cover with breatable membrane then plasterboard. There's a system that uses the fibreglass insulation and another that uses damp proof insulation but both are erected the same.
Looks like it could be quite expensive?
However, these vids make me piss, measure 100 out from bottom of wall same at top......
What happens if walls pissed?
How would you use clips in one across middle if it's sat back two inches.
All very well showing how it's done on a new block wall.
How would this system stop a dew point for the aforementioned condensation?????
Was hoping someone with more experience would have replied to my last post! [emoji1]
Please!
